20 Most Recent Labtec 961307-0914 Webcam Questions & Answers
0answers
0answers
V-UH13 i need a windows 7 drivers
I tried Logitech's driver for a QuickCam Express. The driver worked, but Logitech's software could not find the camera feed. I uninstalled the Logitech software and used Labtec's last iteration of their software. This worked for mine. Driver Labtec Webcams 10 5 1 build 1130b
4/22/2015 2:57:55 AM • Labtec... • Answered on Apr 22, 2015
0answers
8k89 i.t.e camera
Be the first to answer 6/26/2014 3:38:17 AM • Labtec... • Posted on Jun 26, 2014Be the first to answer
0answers
0answers
Labtec download
Be the first to answer 1/23/2014 7:22:38 PM • Labtec... • Posted on Jan 23, 2014Be the first to answer
Zippys web camera 1300k usb driver 2.0 windows 7
how to zippys web camera 1300k driver download
9/27/2013 6:42:20 AM • Labtec... • Answered on Sep 27, 2013
0answers
Driver ZL-350K08011587
1st You download Webcam Driver.Driver ZL-350K08011587After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
3/19/2013 6:45:06 AM • Labtec... • Answered on Mar 19, 2013
0answers
2answers
I dont hace the installation cd for my labtec camera
try to google it, or go to the cams website and see if they provide an installation software for their cameras there had the same problem with my webcam, couldnt find the the installation cd for my cam, but found the installation file at this place www.softpedia.com, try it maybe it will help.
2/24/2013 10:23:27 AM • Labtec... • Answered on Feb 24, 2013
0answers
*** instalez o astfel de camera
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality.
2/2/2013 1:45:03 PM • Labtec... • Answered on Feb 02, 2013
2answers
Hello. I have not driver for my web cam labtec
here... download this driver
labtec_v-uae_13_labtecweb5.1.zip
12/22/2012 11:01:17 AM • Labtec... • Answered on Dec 22, 2012
20answers
ZIPPYS WEB CAM DRIVER
Just follow the link
http://www.zippysltd.com/webcamera_drivers.htm
Thanks
Ashish
10/17/2012 7:08:57 AM • Labtec... • Answered on Oct 17, 2012
397 questions posted
Top Labtec Computers & Internet Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Labtec Computers & Internet
Most Popular Question
zippys web camera 1300k usb driver 2 0
  • Computers & Internet
