20 Most Recent
Hyundai ImageQuest L70N 17" LCD Monitor Questions & Answers
Hyundai imagequest B90D orange standby
hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
12/5/2013 9:54:50 PM •
Hyundai...
Answered
on Dec 05, 2013
Hundai Imgaequest L70N keeps showing
If you restart in safe mode, you need to go to the display settings, and choose a resolution that will work. When you restart back into normal mode, this setting should be retained, and you will be back to normal.
8/4/2011 3:18:50 PM •
Hyundai...
Answered
on Aug 04, 2011
Green power light blinks constantly
Check the caps first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
12/13/2010 4:15:16 AM •
Hyundai...
Answered
on Dec 13, 2010
My Hyundai L70n monitor periodically displays a
That is a problem with the memory array in the monitor. If it is under warranty, don't even mess with it. Take it in. Otherwise open it up and exercise all the connectors on the logic board inside. That works about 30% of the time. If that does not fix it, then it is terminal. They are so cheap now that it doesn't even pay to try to get the repair parts. They will cost more than a new one.
11/18/2010 7:16:17 AM •
Hyundai...
Answered
on Nov 18, 2010
When turning the screen on, the light turn green
This means that the monitor is not getting a signal from the computer. The problem could be the video or graphics card or it could be the monitor itself.
Try to connect the monitor into a known working CPU. If the monitor works, then you need to check your video card.Try to pull out the card and clean it using a DRY clean cloth. And then re-seat the card to the slot. If nothing happen, insert the card into an available video slot. or try different computer. If same problem occur, contact the manufacturer.
NOW, if the problem is the monitor, check the cable, try to use different video cable. If same problem occur, then it should be checked by a technician.
Thank you and good luck!
6/28/2010 8:39:52 PM •
Hyundai...
Answered
on Jun 28, 2010
I want to install the monitor Hyundai L70N but I
You usually do not need a disk to install a monitor, most of them are plug and play capable. If your getting an image that is blurry and out of perspective you may need to change your display size " standard 17 inch is 1280x1024 " If your on XP you can right click on the empty desktop and go to
properties, Under the settings tab you will find options for screen
resolutions. If your on Vista or 7 you right click on empty desktop
space and go go screen resolution,
There again you will easily find your settings for your screen
resolution. Click apply and then click OK. If your still encountering problems such as no image at all you may have a problem with the monitor.
5/9/2010 4:17:17 PM •
Hyundai...
Answered
on May 09, 2010
L70N Monitor driver
http://driverscollection.com/?file_cid=24622933713hBuWizS5I1EwOBkI
12/26/2009 3:05:39 PM •
Hyundai...
Answered
on Dec 26, 2009
The power lite comes on then starts flashing on
The flashing power light indicates a short in the power supply.
This is a common failure point of
LCD monitors after a few years of use. The heat build up in the monitor case causes parts called capacitors to
blow leading to the power supply short. If you can solder you should be
able to do the repair. Go to our web site at:
www.ccl-la.com/badcaps.htm
We have pictures of what to look for. Now take the back off of your
monitor and replace all of the caps that look like the pictures and you
should be back going again. Be sure to use high temp parts, they will
be marked 105c. The values you will need to get will be marked on the
sides of the bad ones such as 220uf, 470uf or 1000uf. When you insert
the new ones be sure to put the polarity stripe going the same
direction as the old one comes out. If you have any questions just let
me know. If you don't want to do the repair yourself we do offer a
repair service for $30 + return
shipping.
We also have a free chat available to talk to our tech 1 on 1
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
11/4/2009 4:57:26 AM •
Hyundai...
Answered
on Nov 04, 2009
My L70N monitor won't turn on it powers up so that
The blinking power light is a sure sign of a power supply failure. The
heat buildup in the case causes parts called capacitors to blow and
short out the power supply making the power light blink. If you can solder then you should be able to do the repair yourself. Go to our web
site at:
we have pictures of what blown capacitors look like. Now open up your
monitor and look at the power supply. Replace all of the caps that look
like the pictures and you should have a working monitor again. The
replacement caps will need to be high temp which is marked 105c. The
values that you need to get will be marked on the sides of the bad caps
you take out such as 220uf, 470uf or 1000uf plus a voltage rating. The
caps can be ordered from several places on the internet or we can
supply them for you. Do not use caps from Radio Shack they are not
rated for this type of use and will blow out in a few weeks of use.
When you replace the bad ones be sure to insert them with the polarity
stripe on the side going the same direction as the old ones come out.
If you have any questions just ask. If you don't want to do the repair
yourself we do offer a repair service for $30 + return shipping.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
10/25/2009 3:42:00 AM •
Hyundai...
Answered
on Oct 25, 2009
Green look
CHECK CABLE CONNECTION TO PC...TIGHTEN IF NECESSARY...IF THAT DONT WORK TRY A SEC MONITOR IF CLEAR U HAVE A BAD MONITOR...IF BAD PIC..THEN U HAVE A BAD VIDEO CARD ON PC
8/31/2009 1:07:01 AM •
Hyundai...
Answered
on Aug 31, 2009
