20 Most Recent
JVC GR-DVF10 Mini DV Digital Camcorder Questions & Answers
I need the manual guid
There are Spanish and French manuals for this camcorder on the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=GR-DVF10
How to play tapes.
Although I don't have that particular camera, I've read that you have, basically, two options. Connect the camera to a USB port and download the tape to the computer (proper software required), then you can can download the file to a dvd. Otherwise, you have to buy a special recording machine (starting about $80) to transfer the tape directly to a dvd.
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
