20 Most Recent Sony Handycam DCR-PC3 Mini DV Digital Camcorder Questions & Answers
Need cable to connect to PC
hi, it is available with me, but no idea about you where is.
2/9/2016 10:20:38 AM • Sony Handycam... • Answered on Feb 09, 2016
0answers
Were can i get a rmt-811 wireless remote commander
You may check eBay or http://www.dealextreme.com website. They do deliver globally.
3/9/2011 3:36:43 PM • Sony Handycam... • Answered on Mar 09, 2011
Hi i have a sony dcr-pc3 my wife bought it in
Well if you have bought the right battery and the proper charger this sounds very odd, did the amp hr and every say the same details on the battery & charger as the old one? when you charge the camera how long was it till you used the camera? as Sony cameras lose around 30% charge per week, I know because I have a Sony still camera and movie, both lose charge, my still camera goes flat in 3 weeks after a full charge with no use at all, so they are never good bits of equipment with batterys.
6/20/2010 4:10:49 PM • Sony Handycam... • Answered on Jun 20, 2010
I like to ajust the
To adjust the date and time on your camcorder, kindly follow the below instructions as shown in the attached images:
The year changes as follows:
1999<-->2000<---....--->2029
To return to FN, press EXIT
Hope this solves your problem. Thanks for using FixYa
5/1/2010 4:46:31 PM • Sony Handycam... • Answered on May 01, 2010
2answers
Driver
Use the site below to download the driver of your camcorder.
http://www.sony.com.ph/support/download/105297/product/dcr-pc330/sectionfirst?subpage=detail
10/25/2009 4:37:49 AM • Sony Handycam... • Answered on Oct 25, 2009
I woul like to put all my digicam recordings onto dvds
You should either download video to a computer (using firewire/IEE1394 connexion), then use a video editing software to build DVD films, or a direct firewire to DVD software (no editing, just dump the video on a disk). This is a bit difficult if you are not accustomed with computers, and takes some time if you want to have nice results. An over possibility is with new home DVD recorder / player, much have now a firewire/IEE1394 input that lets you download atomaicaly from your camcorder to a DVD or the internal Hard drive if the player is equiped with. This last seems to be the best for you if you just want to save your video for further visionning, and don't want to du "cut and paste job" that would be made possible with video editing soft on a computer. Then you should look for a home DVD recorder, and be sure to have it with a IEE1394-Firewire input. I hope this will help.
6/10/2009 12:01:18 PM • Sony Handycam... • Answered on Jun 10, 2009
Unable to connect Sony DCR-PC3 handy cam to my pc
make sure that you are using the correct firewire plugs (4 pin on the camera and 4 or 6 pin on the computer depending on the computer). If you are sure you have all this correct, check your BIOS settings for a disabled media card or 1394 controller.
4/14/2009 6:48:21 PM • Sony Handycam... • Answered on Apr 14, 2009
I WANT TO BUY A
yes
1/22/2009 7:35:50 AM • Sony Handycam... • Answered on Jan 22, 2009
Problems ejecting a tape
Take to a decent camera shop, they probably won't charge fr pulling it out, if it can be done w/o disassembly. They could also give you a better idea on the problem at hand, and you'll be able to make a more informed decision. It could be something small stuck in the teeth of the gears and jamming it. Good luck
12/16/2007 4:33:20 PM • Sony Handycam... • Answered on Dec 16, 2007
Sony DCRA-C162 Camcorder. I need a replacement battery for the DCRA-C162. Does anyone know where I can get one?
Question edited for clarity, add full 'make model (what it is)'. Question moved from Cars and Trucks category. Searching for your manual keeps bringing up this manual https://www.sony.com/electronics/support/res/manuals/2698/26988801M.pdf Looking at that manual Page 16, it states the battery pack as 'NP-FP50', and that turns up batteries for $15. https://www.google.com/search?q=NP-FP50 ..
11/20/2023 12:02:19 AM • Sony Handycam... • Answered on Nov 20, 2023
Sony Handycam CCD-TRV68 Flashing No Tape and Eject Symbol
If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test. Probably too old being 2001 vintage.
11/19/2023 12:20:58 AM • Sony Handycam... • Answered on Nov 19, 2023
SONY mini HandyCam model V569. HOW DO YOU TURN ON A SONY V569?
Question edited to add full model designation. Question moved from Sony Computers. This doesn't seem to be a very well known model. It is not even listed on their website. https://www.sony.ca/en/electronics/support/cameras-camcorders/manuals/results?query=V569# There are normally two batteries, a small one that just saves memory and runs the operating system, and a larger battery that actually powers the camera. Try contacting Sony direct There is a bit of help here, but not enough. https://www.google.com/search?q=SONY+V569 ..
8/4/2023 4:37:50 AM • Sony Handycam... • Answered on Aug 04, 2023
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
4/13/2022 7:57:16 AM • Sony Handycam... • Answered on Apr 13, 2022
Handycam CCD-TRV70 Hi8 camcorder. Why is it suddenly playing all tapes fuzzy, with no audio?
The record / playback heads probably need cleaning, using a compatible cleaning tape. Failing that, it is either damaged or broken.
1/5/2021 11:43:05 PM • Sony Handycam... • Answered on Jan 05, 2021
2answers
Blue screen on TRV260 playback
TRV260 nail-polish head attack: eek. Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation. Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum. Not to mention gumming up the bushes and bearings. With your next camera, rather use a head-cleaner DV-tape.
12/20/2017 4:11:58 PM • Sony Handycam... • Answered on Dec 20, 2017
Sony Handycam DCR-PC3 Mini DV Digital Camcorder Logo
26 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
driver
  • Video Cameras
