20 Most Recent Sony Handycam DCR-HC40 Mini DV Digital Camcorder Questions & Answers
SONY DCR-HC40 video output way too bright
Use your video editing software to correct this
8/12/2017 10:02:54 PM • Sony Handycam... • Answered on Aug 12, 2017
0answers
3answers
Sony handycam DCR-HC20 Screen blank
the ccd image sensor of your camera is defective that why is no image you see..better go to sony service center for replacement of the sensor...
9/11/2013 2:25:00 PM • Sony Handycam... • Answered on Sep 11, 2013
2answers
Digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
8/26/2012 12:10:39 PM • Sony Handycam... • Answered on Aug 26, 2012
Dcrhc40
You may download Sony software here.
5/22/2012 7:23:23 AM • Sony Handycam... • Answered on May 22, 2012
Sony handycam dcr-hc40 will not power on
repair your device again because it has a power ic problem change the ic of your handycam
3/30/2012 7:00:17 AM • Sony Handycam... • Answered on Mar 30, 2012
Memory stick deo not working properly&no audio
try with different memory stick. also try resetting the Camcorder and check the operation.
2/6/2012 6:15:24 PM • Sony Handycam... • Answered on Feb 06, 2012
HANDYCAM DCR-HC40 SCREEN NOT RESPONDING TO TOUCH,
you candownload service manual at following linkhttp://www.fixdevice.com/smanuals/camera/sony/dcr-hc40.htmli hope this solve your problemthanks
10/25/2011 1:46:46 AM • Sony Handycam... • Answered on Oct 25, 2011
Touch screen is not working although i am able to
This is usually caused by a defective LCD / Touchscreen module which is no longer available from Sony at a reasonable price. However, I have a limited supply of them as well as an aftermarket supplier.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
10/11/2011 7:57:58 PM • Sony Handycam... • Answered on Oct 11, 2011
I cannot eject the Cassette
This can be caused by several problems including a defective eject switch in the cameras internal circuitry, a stripped gear or a bad motor. This will require disassembling the camera to diagnose and repair. This can usually be done fairly inexpensively but it's not really a user serviceable problem and should be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/23/2011 7:43:46 PM • Sony Handycam... • Answered on Sep 23, 2011
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
9/1/2011 10:23:51 PM • Sony Handycam... • Answered on Sep 01, 2011
My sony handcam DCR HC20
This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
7/21/2011 6:03:36 AM • Sony Handycam... • Answered on Jul 21, 2011
0answers
2answers
Error c:21:00 is a moisture
Condensation errors are quite common and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
5/8/2011 5:45:26 PM • Sony Handycam... • Answered on May 08, 2011
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
136 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
sony handycam dcr hc40 will not power
  • Video Cameras
