20 Most Recent
LG Flatron L1510P (Dark Gray, Silver) 15" LCD Monitor Questions & Answers
Hey I have an LG Flatron L1718S screen that work fine for a few weeks then suddenly switch off for a few days ,then switch on again,it's a irritating cycle.Please HELP
- Larry Ng Jul 15, 2021that is just a YEAR 2007 LCD computer monitor, it needs a computer to work. if it fails in a 2nd PC ,
if that test fails,the monitor is bad. (hardward failure, monitor.
the tests are simple,
it fails on 2nd good PC, what can be more simple that test ANY 14 year old monitor on a 2nd good PC.
when dead do this.(test2)
they are all here when dead again use a FLASH LIGHT. (or in UK a low carbon foot print TORCH)<< joking.
https://pcdied.com/monitors_and_screens/...
all monitors older than 2010 do this . (has CCFL inside and that is never fun now)
the cure is newer monitors 2011 to now called LED monitor.s or OLED.
the tubes are cold cathode florescent tubes. (back lamps.) (have 5 classic fail symptoms not just dead)
they are short lived,
laptops and monitors both back then. 20,00hours on the clock and go bad. bank on it.
the 3 failures are CCFL, PSU board, and logic board
#1 is CCFL the all died long ago, on average about year 2003 (07 +5= 12, 2012) at 20,000 yours boom dead.
or intermittent.
PSU is here:
below is logic board.
one of the 3 fail, CCFL tubes dead is like 99%
we retire them if the CCFL test fails. (using bench PSU to test them) but you have non of that so. upgrade
Larry Ng Jul 19, 2021
logic board. (CCFL tubes dead, PSU dead, or logic board dead) and or thermally failing , and bad.
Anonymous Jul 23, 2021
99% of all monitors are all dead. due to those silly low live CCFL back lamps.
or the 2cards inside that can fail too. PSU card +HV CCLF power or the Data card is dead.
99.9% of folks seen these facts, upgrade now.
high voltage inside 600v on the CCFL pins
Monitor slow to display picture
Hi, Sounds like an issue of the video card not the monitor. Take to computer shop to verify. One thing you can try is drop the dpi down (refresh rate)a bit. Then try again. If that makes sense to you. Hope that helps.
Installing mount on LG Flatron
It´s not safe to anchor it to the plastic back, monitors usually have a metal frame inside that support the weight of the monitor.
Lg flatron e2441 half screen darker
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
FRATRON SCREEN NOT WORKING
are you in dual screen mode on a laptop possibly? Check that the laptop is dual enabled so that it is either an extension or a duplication of your main screen. This is common mistake in setting up external monitor on laptop.
How to stretch screen to fit monitor
you need to look at the geometry settings on the video driver on your computer to find the right set for your monitor. There is some adjustment in your monitor to choose 4:3 or 16:9, but in PC mode this is usually over-riden though.
Settings won't save
check your VGA cable and connector that it is securely connected. Sounds like the blue is open or disconnected. If not, the video card on the PC or the receiving card in the monitor is going out,
