20 Most Recent
Ocean OK Rudder Kit - Drifter, Zest, Prowler 15 Questions & Answers
Dent in hull of kayak
umm....plastic or composite? If it's plastic, sit it out in the sun or carefully heat the dent with a heat gun and gently push it back out. Happens all the time.
If it's a composite or a rigid plastic kayak, you have a nice repair job ahead of you that won't fit into this space comfortably.
What are the best ocean fishing kayaks for 2018?
Fishing in the deep sea is very much adventure. Fishing and kayak two are the most popular thing for enjoyment and it's also favorite hobby most of the people all over the world and the notable think that day by day its increase its popularity. when someone wants to go for fishing in the ocean, he must have to select the best fishing kayak which one suitable for him with more update features. The most important is that he has to select the sea kayak because there have a lot of types kayak in a market.In the market, here have many brands for a kayak. Each brand has their best kayak for ocean kayak. It depends on the budget, design, features. I thank the Vibe Kayaks Skipjack 90 is the best for it. For more details about ocean fishing, you may check here
Best Inflatable Kayaks in 2018 List of The Top Selling Models
I have a 2000 150 johnson outboard was runing
Disconnect blk wire with yellow strip, from the power pack. Try restating motor and see if that cleared it up. If so, you have disconnected the kill wire at power pack.Let me know what that does for you.
10/8/2017 7:37:10 AM •
Boating
Answered
on Oct 08, 2017
My ocean pro 225 will tilt up but when I try to tilt down the motor doesn't run
If this happens at both the command points ( remote control AND lower engine cover buttons) then check your relays.
You'll find both relays at the engine, 2 black cubes about 2cm wide.
The relay with green wiring is for down movement. The blue wiring is UP.
Switch both relays. If the engine goes down but not up. replace the relay. Otherwise check the wiring. One will be loose or broken.
Can you refinish a plastic kayak
No poly-plastics of the type used in manufacturing can only be armor-all surface cleansed but makes the craft very slippery to lift and use. Color is restored though. Make sure there are no brittle areas that have been 'cooked' by the sun while stored in a yard. IMPORTANT!
How to find leak in ocean kayak.
fill the kayak using a hose and the drain-hole. every ocean kayak has a drain-plug. with water going into the shell, any holes will show up. Drain water and use.
CHANGE STUDS ON BOAT
http://www.sailnet.com/forums/gear-maintenance/49777-dropping-keel.html
I found this site for you, I have never been involved in pulling a keel or removing lead, so you are on your own, check this out.
2/24/2010 3:53:26 AM •
Boating
Answered
on Feb 24, 2010
I have a 2002 ox66 Yamaha 2 stroke 250 hp std
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
11/18/2009 7:36:09 AM •
Boating
Answered
on Nov 18, 2009
How do you put an odometer on a kayak
The best solution is a good marine GPS unit. It will have options to plot your course and give you elapsed distances. I don't own one myself, but many of the people I paddle with do...and it's fascinating to see how many miles are added just bouncing back and forth across the missouri or the mississippi during a putatively 20 mile jaunt.
Just remember, even if it claims to be water proof, a clear drybag is your friend...why put "water proof" to the test if you don't have to?
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
