20 Most Recent
HP Photosmart 2410 All-In-One InkJet Printer Questions & Answers
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Need cd to install hp
You can find all the downloads you need here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=303753 If that doesn't work, visit this site: http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us&product=top and enter Photosmart 2410 in the box under Locate your product to get support.
I can send faxes, but
I would uninstall it and reinstall making sure that you don't miss a little unchecked box and that you have the correct number and applications installed. At least you would be renewing the driver and, very often, this can fix the problems you have. Go onto the support page at HP and look in the FAQ's. You won't be the 1st to have this problem. Hope that helps.
Not scanning
uninstall printer and reinstall after rebooting.
Use the latest drivers for your operating system.
Some functionality can disappear when the drivers are not fully installed with the latest ones.
Good luck on this.
Need software download
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=303753&lc=en&cc=sg&dlc=en&lang=en&cc=sg&submit=GO
Unfamiliar noise when first switched on
Hello there
It just best to try this.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Hello there
You may not see a paper jam.
Yake care.
I lost my cd installer
Download drivers and software here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90809&lc=en&cc=uk&dlc=en&submit.y=6&submit.x=9&lang=en&cc=uk
My HP 2410 Photosmart printer is making a clicking
Uninstall the printer completely starting from the software.
Go to Start Menu, Control Panel, Add/Remove Programs, select the HP Photosmart software and remove it.
Then, go to Start Menu, Control Panel, Device Manager (usually under Administrative Tools/Computer Management).
Select under "Printers", the HP Photosmart 2410 All-in-One InkJet Printer and remove it.
Restart your computer and follow the instructions from your HP manual to setup your printer again.
