20 Most Recent
Sony VAIO FRV27 Notebook Questions & Answers
Dvd drive wont recognize disc
There are a number of possibllities for this problem:
1. Your drive may be dirty. Try to get a drive cleaner, run it then try again
2. The disc itself is faulty. Try using it on another computer's drive and see if you can read it
3. It is a region-specific DVD. Some movies can only be played on DVD's made for that region. Although you can change your DVD's region to be able to read that DVD, you will then not be able to read DVD's for your current region. The recommendation here is to buy a multi-region DVD player. You do not need to get the top of the line model as these players can be quite cheap.
NOTE: Please rate our help to keep this free service online.
Sony vaio pcg-frv27 turns off after a while, I'm
Most likely overheating, check if it is getting hot as it shuts off, by hot I mean hard to touch the base.
If it is, you will need to remove the bottom cover and clean out the accumulation of any dust by the heatsink
Power on brings the first screen
Before Vaio comes up, start pushing F1 or F8 or F11. If it lets you in to restore your comp, do it. That's the only way to fix this. You will lose all your files and info on your laptop though.
Fn key
Try installing the "Sony Shared Library" and the "Sony Notebook Control Device Drive".
First install the Sony Shared Library, restart the Computer and then install the "Sony Notebook Control Device Driver" (restart the Computer again).
NOTE: Sony Shared Library is the system component which makes the download and installation of Drivers and Applications compatible with the Computer. While "Sony Notebook Control Device Drive" is utility which will enable the Function keys in the Computer.
Check this
Link to download these Utilities.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGFRV27The Sony Shared Library will be listed under "System Components - 1 file(s)" and Sony Notebook Control Device Driver will be under "Notebook Control and Utilities - 1 file(s)".
Good Luck!!!!!!!!!!!!!!
Hi guys, I keep getting an error message that
Try rebooting and hitting the F8 repeatedly as soon as the boot sequence starts. When it comes up to an options screen select repair. From there you can let windows try to repair or select to install to the factory settings.
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM •
Sony VAIO...
Answered
on Jan 22, 2018
My laptop has limited internet access. I've called
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
12/28/2017 11:26:53 PM •
Sony VAIO...
Answered
on Dec 28, 2017
