20 Most Recent AcerScan 620S Flatbed Scanner Questions & Answers
Good morning. Yesterday my uncle gave me a Acer
suggest looking in file manager at cd directories and see if any are labelled as driver - windows xp see if any have an INI file type Try also adding a device in control panel - devices. Then when it comes to driver part - select have disk and then point the have disk to the cd rom drive and you may have topoint it to the directory as well. It should find a (whatever file name).INI . type file .
5/8/2017 12:47:12 AM • AcerScan 620S... • Answered on May 08, 2017
0answers
4answers
Driver acerscan prisa 620p/620s driver for xp
I would like to get the driver for Acerscan Prisa 620S scanner
1/25/2013 5:11:51 AM • AcerScan 620S... • Answered on Jan 25, 2013
Acer Prisa 620p flatboard scanner
load new driver for xp, on acer site.
11/6/2010 6:17:53 AM • AcerScan 620S... • Answered on Nov 06, 2010
2answers
Acerscan prisa 620p driver problem
You can download an up to date XP driver for this scanner from
http://www.bioticaindia.com/acerscan-prisa-620p.html
You will need to register and login but it is free.
7/27/2010 4:47:43 PM • AcerScan 620S... • Answered on Jul 27, 2010
Pls send me the driver for 620S Vudeo scanner
You can download Acer Scanner driver from this site.
Acer Scanner Driver
3/21/2010 8:08:57 PM • AcerScan 620S... • Answered on Mar 21, 2010
Iam having a acer prisa 620s flatbed scanner model
just download the model of acer prisa 620 flatbed scanner or goto www.drivercollection.com or www.driverguide.com
3/4/2010 2:22:06 PM • AcerScan 620S... • Answered on Mar 04, 2010
I need a drver for my Acerscan color flatbed SCSI
Hi.
Acerscan products are not distributed anymore. There is no Windows 7 driver that will work, this for any Acerscan model.
You can try finding A SCSI adapter that works on Windows 7 and let the adapter SCSI BIOS manage the scanner. The original SCSI adapters distributed with this scanner will not work on Windows 7.
If you really want to use this scanner on Windows 7 you will have to buy a new SCSI device, and the scanner may still not work.
My suggestion is upgrading the scanner, I know that this unit are not cheap. Get a USB scanner compatible with Windows 7.
Regards.
2/23/2010 1:33:52 PM • AcerScan 620S... • Answered on Feb 23, 2010
2answers
Acer Prisa 620S scanner
If this scanner was previously used on a Win95/8/ME system the likely hood of it working with and NTFS[3000/XP] system is slim. This is because the two system work in different ways and the scanner design for 95/8 does not recognise commands from a NTFS computer. Two thing to try Go to Mt computer/Help/Compatibility and read it up. then right click on the scanner software and click on properties/compatibility and set it to Win98- see what happens You could checkout ACER for driver updates also. But don't hold your breath
12/25/2009 12:41:00 PM • AcerScan 620S... • Answered on Dec 25, 2009
Need driver for acer peripheral 6696-0qe
You can go to Acer's drivers site and download the driver detector. It should recognize your scanner and let you download the proper drivers.
http://www.driver-download.net/acer/scanners/6696-0qe/
Good Luck
5/4/2009 1:15:51 AM • AcerScan 620S... • Answered on May 04, 2009
REACTUALISER ACER 620S pour l'utiliser avec XP
Use the acard driver, it can solve the problem
2/11/2009 11:09:33 AM • AcerScan 620S... • Answered on Feb 11, 2009
Hi
If you go on the manufactures site they will have more info that will help you---you may have done this --then ignore this reply.
jay
12/20/2008 9:55:00 PM • AcerScan 620S... • Answered on Dec 20, 2008
AcerScan 620P - connect to USB port
how i can load driver
12/2/2008 1:48:00 PM • AcerScan 620S... • Answered on Dec 02, 2008
3answers
Not support window xp
8/25/2008 11:28:55 PM • AcerScan 620S... • Answered on Aug 25, 2008
New driver
I searched through BenQ site as they were previousily Acer Communications or something which made this and other scanners and it only has drivers that are supported up to Windows XP.
http://www.benq.us/support/downloads/downloads.cfm?product=159&page=downloads&dtype=D
That link will take you to the US driver download page for your scanner, change the country to whatever country you reside in. It may work with Vista if you run the driver update as a XP program with the compatibility wizard or when you install the scanner. If that doesn't work, I'm afraid you may just have to go buy a scanner that will run with Vista or an all in one printer that is supported in Vista.
2/29/2008 4:23:57 AM • AcerScan 620S... • Answered on Feb 29, 2008
ACERSCAN 620 ST NOT RUN TO WINDOW XP
check for the drivers for windows xp in the manufacturer's site or try at www.drivers.com and install the driver in windows xp that's all your machine will work.
11/5/2007 3:34:54 PM • AcerScan 620S... • Answered on Nov 05, 2007
AcerScan 620S Flatbed Scanner Logo
Popular Tags
32 questions posted
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
AcerScan Acer
  • AcerScan Acer
Most Popular Question
iam having acer prisa 620s flatbed
  • Office Equipment & Supplies
