20 Most Recent Invacare Pronto M91 with SureStep Questions & Answers
One green led just flashing & just gos very slow
Have the battery tested it must be failing.
9/21/2016 8:49:06 PM • Invacare Pronto... • Answered on Sep 21, 2016
Spj-80, model 1122190. Why doesn't it move?
you may have a current rollback problem you will need to charge the Chair for 14hrs. with the Joystick on! This will reset the circuit. Charge with the joystick on! It is okay it won't hurt a thing, in fact from now on always charge with the joystick on. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
4/12/2016 5:54:41 PM • Invacare Pronto... • Answered on Apr 12, 2016
Why does my chair slow down, and then stop? It's not the fuses or the batteries.
hi again if u got youre batteries tested with a battery load tester 100 amp similar to one in photo ok then u have to get youre control box checked and youre joy stick to find out the problem ...good luck.... hi get youre batteries tested with a ( battery load tester )the lights on youre scooter r not a true reading on the condition of youre batteries..good luck033364c5-468c-47d8-a01b-5155788580b7.jpg
10/5/2015 2:48:18 PM • Invacare Pronto... • Answered on Oct 05, 2015
How to recharge batteries.
Hello,i would check with the manufacturer for the charger.Remember,if you do not follow guidelines set out.It could affect any guarantee.I am disabled myself & the batteries are not cheap,even though VAT is not charged for us.When you provide proof of Disability.I hope this helped.
6/3/2014 4:11:16 AM • Invacare Pronto... • Answered on Jun 03, 2014
I hear a click in the motor when I engage the joystick. What acn it be?
You need to worry when you don't hear a click
4/30/2013 10:54:44 PM • Invacare Pronto... • Answered on Apr 30, 2013
Invacare pronto m91 wheel chair not getting any power to the switch. Is there a fuse somewhere?
Hello,Download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as A PDF File.It is full of info & you can diagnose your problem to select part required.I hope i have helped,have a nice day,Colin
4/2/2013 10:55:36 PM • Invacare Pronto... • Answered on Apr 02, 2013
Reset of dash lights RE. Potentiometer -
hi John, the tiller display you got on that scooter , if all of the lights are coming on even when the battery power is low sadly is a faulty component, they are cheap to repair and is now a common problem because they quite old .. Regards Rob
1/30/2024 8:44:32 PM • Invacare Health... • Answered on Jan 30, 2024
I have a invacare reliant 350. It is the sit to stand, model number RPS350-1. How come when using the controller the up feature works but the down feature don't?
Is the down feature not working the one and only problem, please? What happens 'when using the controller' suggests there are other options, for instance using not 'the (remote?) controller' but rather the controls on the unit itself. Does that make no difference, please?
1/28/2024 11:08:10 PM • Invacare Health... • Answered on Jan 28, 2024
I own an Invacare Envoy IRC1192 aerosol compressor breathing machine and I need it to be cleaned before I use it again I just acquired COVID-19. Can someone help me.
Question edited for clarity and to give its proper title. Question moved from Washing Machines category. You need to clean and sterilize it now and then when you get a negative test. http://www.invacare.ca/doc_files/93_42.pdf You need liquid sanitizer or Dettol. https://www.google.com/search?q=invacare+irc+1192+cleaning+instructions ..
9/20/2023 7:54:15 PM • Invacare Health... • Answered on Sep 20, 2023
Invacare M91 New Batteries Installed, Lights Up but Won't Move
The orange light on solid should signify it is charging. If the orange light flashes, you count the flashes and that is the error code http://www.invacare.com/doc_files/1125038.pdf https://www.google.com/search?q=invacare+m91+orange+wrench+light ..
9/20/2023 12:35:17 AM • Invacare Health... • Answered on Sep 20, 2023
I have another problem with my Invacare Pegasus mobility scooter.
You have to get in behind it and see why it pushed back in? Then you can push it back out or re-fix it, or get a new charging socket.
Invacare Corporation - Parts Catalogue
Invacare http://www.invacare.ca > inv_catalog > partsPHII_home Parts Catalog. Invacare Home ' New Search. Choose Product Category. Product Category, Beds and TSS, Power Wheelchairs & Scooters, Manual Wheelchairs ...
Invacare® Pegasus Series
Invacare http://invacare.ca > doc_files > Pegasus Owners ... PegasusMETRO, PegasusPRO en Scooter ... 7.2.4 How to disconnect the batteries after charging. ... liquids may require replacement of electrical components. 66 pages ..
9/2/2023 1:38:38 AM • Invacare Health... • Answered on Sep 02, 2023
I have an Invacare Pegasus scooter. I've tried to charge but it's still and won't go to green for full charge. On the charger it shows a flashing orange light twice then 5 flashing green lights.
Contact Invacare direct. I can't find anything on Charger Blink Codes, only for the scooters.
Invacare® Pegasus
Invacare http://invacare.ca > doc_files 4) Wait two seconds until the appropriate blink code is displayed on the battery charge display, then release the keys. Do not hold the keystroke combination ... 72 pages ..
8/26/2023 11:05:30 PM • Invacare Health... • Answered on Aug 26, 2023
Invacare Leo back wheels seizing up and also hard to push without locking in freewheel mode
hi Helen, firstly the scooter will lock up after a couple of metres , that is by design to stop you rolling down a hill etc .. Now if the scooter is hard to push even in freewheel, means the brake has either decided to seize (lack of use , been in storage ) or has become damage. The mechanism for releasing the brake has become damaged . brake removal recommended then try to push the scooter , if it 's okay then its the brake if not , it could be the coupling between the motor and gearbox has failed or the gearbox itself has a issue,. Regards Rob
7/5/2023 8:08:20 PM • Invacare Health... • Answered on Jul 05, 2023
I have a Invacare P9000 XLT Powered Wheelchair. The lights flash 6 times. Any help would be appreciated.
Page 37 of the Electrical Service Manual refers 6 Flashes E06 Right Park Brake Fault http://www.invacare.com/doc_files/1110532.pdf ..
4/24/2023 9:38:10 PM • Invacare Health... • Answered on Apr 24, 2023
Are both lights supposed to be green i have 1 red 1 green on my battery for my invacare scooter
Mine is an Invacare M51 Pronto Surestep with an onboard Winsunny battery charger. My charging lights are solid red and green/ yellow. Depending on if it is charging or not. What kind of charger do you have? I have to replace my charger because it is not working. My green light is staying green while charging even though my joystick is showing my batteries are depleting and I just got new batteries. sigh.
4/24/2023 4:51:31 AM • Invacare Health... • Answered on Apr 24, 2023
Invacare Pronto M91 with SureStep Logo
Popular Tags
10 questions posted
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Invacare Health & Beauty
Most Popular Question
chair slow down stop s not fuses or
  • Health & Beauty
