I have a belling gas
When the
oven lighting mechanism lights the gas, the flames heat a temperature sensor
that, once hot, increases the pressure in the sensor's copper pipe and opens a
safety valve to allow gas to continue to flow without you holding down the button (It's made like this so, if your
flame gets blown out, the sensor cools and cuts off the gas supply, making it
safe from gas leaks). These sensors occasionally fail, and very sensibly
"Fail safe" - No pressure in the sensor pipe, the valve won't stay open
and there is no gas to the burner once you release the button.
If you take
a look inside the oven at the back where the burner is, you will see the
sensor, usually the bit that is in the flame is cylindrical, about an inch long
made of metal about 3 or 4 mm thick, tapering at the end. It will be held in
place by a nut that fits on a thread at the base of the sensor. Running from
the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor
and withdraw it from the hole it is mounted in, trace the copper pipe back to
the valve (where it is usually screwed into the valve with a 10mm connector
that looks like a car brake pipe connector. Unbolt from the valve. These
sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob
burners and patio heaters all use the same kind of sensor). You should be able to
get a replacement from any gas appliance service agent. If you go into a shop,
take it with you. The only thing you need to do is make sure the replacement
you get is long enough. If you are offered one that is slightly longer, that
7/22/2011 10:36:15 AM •
Belling...
Answered
on Jul 22, 2011
