20 Most Recent Epson Stylus C66 Inkjet Printer Questions & Answers
3answers
Epson stylus c66 is new but in printing paper comes out blank
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
12/2/2022 11:38:19 AM • Epson Stylus C66... • Answered on Dec 02, 2022
Why is my epson printer not printing red but comes out as yellow
Red is made by mixing yellow and magenta ink. it would appear the magenta system is blocked
3/5/2015 9:28:55 AM • Epson Stylus C66... • Answered on Mar 05, 2015
5answers
Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
10/27/2014 3:53:33 AM • Epson Stylus C66... • Answered on Oct 27, 2014
0answers
2answers
C66 printer head Clogged
  • If the print head has become clogged and the printer's head-cleaning cycle won't help (run it 10 times if you have to) you could try these things:
    • Soak the print head in hot water then leave it overnight, then try it again
    • If you have access to an ultrasonic cleaner that will take the printhead, use that. (These are used by jewellers and other people which have to clean small, intricate parts)
    • Buy some Isopropyl Alcohol and soak the printhead in that overnight. (You can get it from the chemist)
    • Use a Mr Cuppacino (or your Espresso machine). It's a small kitchen appliance which creates a jet of steam for frothing milk for making a cappuccino. You can use the jet of steam to blast the print head. But be careful that you don't melt things -- short, sharp jets only.
    • Each time you try a cleaning method, use a damp paper towel to gently wipe and dry the print head area.
    • Put a teaspoon of water in the bottom of the empty cartridge and try the cleaning cycle a few times.
  • 7/8/2013 3:56:59 PM • Epson Stylus C66... • Answered on Jul 08, 2013
    New laptop but no disc for installing printer
    You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and
    select your model printer todownload :- http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
    8/30/2011 12:00:32 PM • Epson Stylus C66... • Answered on Aug 30, 2011
    Paper wont feed through myepson c66
    Some times the paper is the problem. it may damp or old replace it. else the rubber finger that grabbs the paper may need to be replaced.
    8/29/2011 5:41:01 PM • Epson Stylus C66... • Answered on Aug 29, 2011
    I have renewed the black ink cartridge but the
    there is a utility in your printer software , using that you can clean the head of the printer, if this does not solve your problem use the alignment option from that utility
    7/29/2011 2:23:36 PM • Epson Stylus C66... • Answered on Jul 29, 2011
    I have installed new ink cartridges but when I
    Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
    Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    Don
    7/14/2011 7:59:19 PM • Epson Stylus C66... • Answered on Jul 14, 2011
    Epson c66 prints the wrong
    did you install the catridge correctly?
    6/12/2011 10:37:44 AM • Epson Stylus C66... • Answered on Jun 12, 2011
    Changed the ink cartridge twice and still very
    If you have tried with fresh ink cartridges, It sounds like the print heads may be clogged/dirty.
    You should be able to find a cleaning option in the software for the printer. Try doing a cleaning cycle this way. You may need to do it several times to see a difference. If this doesn't help, maybe look at a new printer. It may cost almost as much for service, as a new printer will cost you.
    Hope this helps!
    Joe
    6/4/2011 6:44:22 PM • Epson Stylus C66... • Answered on Jun 04, 2011
    2answers
    Epson stylus c66 installation without
    You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
    5/18/2011 10:28:15 AM • Epson Stylus C66... • Answered on May 18, 2011
    What does it mean that
    This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
    To unpause a printer
    1.) Left click Start in the bottom left hand corner of the screen
    2.) Left click Control Panel
    3.) Now, double-click "Devices and Printers" or "Printers and Faxes"
    4.) In the Window you will see your printer, double-click your printer
    5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
    Hope this helps :)
    5/15/2011 5:33:09 PM • Epson Stylus C66... • Answered on May 15, 2011
    I need a disk to
    Hello and Welcome to FixYa!
    You can download the driver according to your Operating System from the Epson Support section, here.
    If you have any Confusion, questions or issues regarding your problem do tell me.
    Thank you for using FixYa!, Keep visiting..
    If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
    Concerned, Nooh
    3/26/2011 6:42:13 PM • Epson Stylus C66... • Answered on Mar 26, 2011
    Epson Stylus C66 Inkjet Printer Logo
    140 questions posted
    Top Epson Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    NH TECH
    Level 1 Expert
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
    View Most Popular
    Stylus Epson
    • Stylus Epson
    Most Popular Question
    mean
    • Office Equipment & Supplies
