20 Most Recent
E-Mu 0404 Sound Card Questions & Answers
Audio Recording Problems
try using the windows sound recorder to see if that records music? if it doesnt then you need to go into your sound recording properties and change it from mic to wave
Driver emu
Depending of what OS you are using the drivers should be available from the manufacturer's site, or if you are in to penguins at least on the Ubuntu-fork of Linux It should work with ALSA and/or PulseAudio from 12.04 and newer.
Emu 0404 stopped working
right click on the icon of the emu 0404 in the tastbar and click on restore defaults your system will do a restart and your sound will be back
Computer hang up
Nothing is wrong with sound card.
The Problem may be...
1. Media Player
Solution: Try playing with different media player.
2. Virus
Solution: Scan you HDD with antivirus software.
If that doesn't work then...
3. in OS / System
Solution: Backup your data, format your HDD, and reinstall you OS.
Please Rate if you find the above info useful.
EMU 0404 PCI express.
Will
When you do have ParchMix up and running, single-right-click the blue striped icon in your system tray (lower right corner of screen) and choose Restore Defaults from the popup menu. By default, PatchMix should start each time your computer is booted up.
Low sound production from my EMU 0404
Are you sure the problem is with the sound card? May be it is the volume settings. There are several ways to increase the volume.
If you need further help, let us know the model, brand and OS of your computer.
I have a problem with
Base from the description of your problem and from all the details that you provided us including the things that you already tried doing to correct the problem these is definitely a hardware issue with the sound card that you have purchased second hand.
Hi, I have E-MU 0404
There should be 2 analogue outputs on that sound card. Also make sure that all sound are set to the default sound card. There should be a check mark along with the sound card.
The sound displayed "application failed
make sure that the sound card is securely seated with no dust in the socket then uninstall it restart your computer and reinstall the sound card and its drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
hope this helps
EM_U 0404 was working find
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
My driver is not digitally signed
The driver not being digitally signed means that microsoft didn't give the company there "seal of approval" which means the hardware wasn't verified by Microsoft and is not up to there lofty standards. As long as the hardware installs and you can get it to work, that is what matters. Not whether Microsoft gives there seal of approval and gets more money out of companies for that privilege.
Hello...
You should Reinstall your Sound Driver.
- Go to the control panel
- Click on the System Icon
- Click on the Hardware Tab
- Click on the Device Manager then
- Click on the Sound, Video and Game Controller then
- See the Audio Driver is in the list.if it is available then
- Right Click on the Audio Driver the Click on the Update Driver and update diver wizard will start.and your driver will be reinstall.
If You want to download different types Drivers.You can download from this site.
Download Drivers
E-mu 0404 USB - Connected
Click open the Volume Icon from the system tray and check if any of the items are not muted. Unmute it and then play.
Sound stopped working on my computer alltogether
This is a generic issue with all Windows OS updates....many of the users are facing this issue....this issue began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just doing FREE service to help everyone affected by this stupidity from Microsoft.
www.sureshayyar.110mb.com
visit my Support Page.
many of us are victim of this “stupid” update, my office has 24 PC/Notebooks and almost all of them got this issue one by one in 4 months time period, I head the tech dept here.
all the best...
Kindly leave a feedback/rating to this solution as it will help me understand if my solution worked
E-MU 0404 Soundcard no longer functions
Reinstall the software driver for your soundcard to make it work. If you have the disc, just insert it and reinstall,
otherwise, you have to download it from the internet.
