20 Most Recent Visual Land V-Touch Pro 4GB, Blue ME-965L-4GB-BLU Questions & Answers
My V-touch Pro won't respond to charging and has seemed to have permanently turned off
Have you tried resetting it?
4/28/2013 10:03:06 PM • Visual Land... • Answered on Apr 28, 2013
0answers
My keyboard will not work on my new visual land prestige elite
1. If your keyboard is not Bluetooth-enabled, it will never work with your tablet. 2. If your keyboard is Bluetooth-enabled but your tablet is not, it will never work with your tablet. 3. If both your keyboard and your tablet are Bluetooth-enabled, connect your keyboard to the tablet using Bluetooth as per the set up instructions that must have come with the keyboard.
12/21/2016 5:57:02 PM • Visual Audio... • Answered on Dec 21, 2016
My Visual Land mp3 player will not turn on unless it is in the charger....
Sounds like the battery isn't accepting a charge any more. Google the manufacturer to see if replacement batteries are available.
10/22/2016 7:34:44 PM • Visual Audio... • Answered on Oct 22, 2016
My visual land tablet went blank while I was using it and I can't get it to do nothing, How can I fix this problem?
Hello, You need too make sure that the power cord is actually charging the unit. If not replace it. If it is, then remove the battery and let set for 2 mins., then put back in and try powering up. IF that doesn't work, you will have to get ahold of your tablet manufacturer cust support and go thru their trouble shooting procedures.
5/17/2014 9:44:08 PM • Visual Audio... • Answered on May 17, 2014
0answers
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
4/24/2024 7:18:55 AM • Audio Players &... • Answered 2 days ago
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered on Apr 20, 2024
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
Visual Land V-Touch Pro 4GB, Blue ME-965L-4GB-BLU Logo
1 questions posted
Top Visual Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Visual Audio Players & Recorders
Most Popular Question
v touch pro won 39 t respond charging
  • Audio Players & Recorders
