20 Most Recent
Lexmark Optra Color 1200 Led Printer Questions & Answers
The black ink stopped working but is still
Printer estimates how much ink is left in the cartridge and there is no way it can know excact amount of ink. You should install another another one.
pls vote so I may continue sharing
Can install Lexmark all in one 1200 series in
1st You download Printer Driver.
Lexmark Printer Drivers For windows 7
After this install the Printer driver in the system.
Installation of Printer Driver
- Go to the control panel
- Click on the System Icon
- Click on the Hardware Tab
- Click on the Device Manager then
- Select the Unknown Device or printer device where yellow Question Marks sign on it.
- Right click on it and uninstall it.
- After this go to the top of the device manager and click on scan for hardware changes.
- Driver installation Wizard start.
- Brows Your Driver from the Hard Disk and click on next.
- Driver will be install.
Don't have CD for installation
Hi
You can download a driver Software from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the
Lexmark-Optra-Color-1200-XP-and-Mac
Link=
http://www.4all2sell.com/driver/Lexmark-Optra-Color-1200-XP-Mac-.EXE
Ones you have downloaded just double click
and it will take you through the installing
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.All The Best: Pineworks
Lexmark 1240...
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Printed pictures comes out red
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
PRINTER SHOWS NO PAPER IN DRAWER
There is a sensor that detects paper just after the paper tray. No matter what is the reason that paper doesn't reach the sensor your printer will indicate that there is "no paper".
You should check is something preventing transport system even to reach the level of paper. In the case of Lexmark E342 or E250 printers, for example, two wheels with black rubbers rotating around common axis are pushing the paper . When you pull out the paper tray the transport system with rollers can be seen from the bottom side of the printer. If the rollers are not laying on the surface of the paper they can not push it inside the printer.
If you are sure that it is not the case the next thing you should check is the rubbers mentioned above. They must be clean enough to have efficient traction with paper. You should take the rubbers off the wheels, wash them with water and soap, rinse them and thoroughly dry. Put them back and try.
