20 Most Recent Apple iPhone 4S 64GB Factory Unlocked Phone White Questions & Answers
Can I replace a battery for iPhone 4s to battery with 2680mah ??
Generally look for a "certified by apple" mark. You could also look for an aftermarket product from companies like "mophie" (www.mophie.com), for a case with a built in battery.
2/23/2015 2:47:11 AM • Apple iPhone 4S... • Answered on Feb 23, 2015
Sending photo's from an iphone at a photo kiosk
Is the kiosk manned with people? You can attach your photo to an email, and send the email to them! Good luck
2/7/2024 6:04:13 PM • Apple Cell... • Answered on Feb 07, 2024
2answers
I forgot my apple password
To reset your apple password 1 go to settings 2 tap your name>Password & Secretary >Change Password 3 Follow the onscreen instructions to reset your password.
9/3/2023 9:56:48 AM • Apple Cell... • Answered on Sep 03, 2023
2answers
I must reset my apple ID
Hi there, you can try TunesKit iPhone Unlocker to Remove Apple ID on Apple Cell Phones. Here a step-by-step tutorial: Step 1. Connect your iPhone to your computer First, get your iphone connected to a computer. Then launch TunesKit iPhone Unlocker, and select the Unlock Apple ID option. unlock-apple-id-4vy0pwrh42ffy145mzbxq1gb-d-0.png Step 2. Setting confirmation If you have Find My iPhone enabled on your iOS device, you will need to confirm that a passcode is set and turn on two-factor authentication on your iPhone. If the Find My iPhone feature is disabled on your device, you can skip directly to the next step and tap the "Start" button to unlock your Apple ID quickly without losing data. confirm-device-status-4vy0pwrh42ffy145mzbxq1gb-d-2.png Step 3. Remove Apple ID Once confirmed, TunesKit iPhone Unlocker will start downloading the matching firmware and then remove the Apple ID from your iPhone. unlocking-apple-id-4vy0pwrh42ffy145mzbxq1gb-d-4.png
7/28/2022 6:51:57 AM • Apple Cell... • Answered on Jul 28, 2022
2answers
Download lite mega codec pack
K-lite codec pack is free and safe, and it includes almost all video codec and audio codec. K-lite codec pack download link
7/14/2022 9:25:45 AM • Apple Cell... • Answered on Jul 14, 2022
2answers
Please can you reset my apple password
There are different methods to reset iPhone password. Just follow the below steps to reset Apple password. If you haven't synced your iPhone with iTunes before or if you haven't enabled your Find My iPhone on, you can take advantage of the third method. Resetting iPhone Password in Recovery Mode is not complicated. The steps below will show you how to do that. Step 1. Disconnect all cables from your iPhone and turn it off. Step 2. Press and hold the Home button and connect your device to iTunes. If your iPhone does not turn on, please turn it on manually. Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode. Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone. Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you reset iPhone password with Recovery Mode. Therefore, please consider carefully whether you need to use this method to reset password on iPhone. If you remember your current iPhone password and you just want to change into a new password, you can finish it with ease. Go to Setting > General > Touch ID > Passcode (iOS 9/8/7) or Passcode Lock (iOS 6), then enter the current password and tap Change Passcode. Then enter the new passcode. Now, you have reset your iPhone password. For more methods, check: How to Reset Password on iPhone
4/25/2022 2:33:38 AM • Apple Cell... • Answered on Apr 25, 2022
2answers
I have an Apple Watch 3. It continually loads silent mode and the weather app by itself. The weather app flashes continually. I have unpaired and re-paired. Now turned off cover to mute. Any help
Hi, You didn't mention which iPhone model it's paired with, but here are two things you could try: - erase the Apps on you watch and on your iPhone, and reinstall them. - using your web browser (Safari), search for "how reset your Apple Watch 3"
3/1/2022 11:51:38 PM • Apple Cell... • Answered on Mar 01, 2022
2answers
How do i use airplay
To use airplay, you must be on the same WiFi network as the speakers/Apple TV you would like to stream your multimedia to. Once you're on the same WiFi network, open up an app (Music, for example) and select a song to be played. Once on the Now playing screen, at the bottom of the screen a little icon should appear that looks like this (http://www.applegoss.com/wp-content/uploads/airplay-logo.jpg) click on it and choose your AirPlay streaming device. The music should now play over the speakers you've selected. The protocol is extremely similar for all other applications and videos.
1/21/2022 7:35:43 AM • Apple Cell... • Answered on Jan 21, 2022
2answers
3g iPhone switched to E even though i'm in my
The structure/location of your house may cause signal interference. One of my former workplaces had almost no signal throughout their building.
An easy solution would be to set up wireless internet at your home and switch your phone to wi-fi while you are home. This would actually be faster than 3g internet.
1/12/2022 2:31:25 AM • Apple Cell... • Answered on Jan 12, 2022
What is my Apple ID.?
It is located in Settings. Click on your name in settings and then scroll down to name and click on there. Scroll again and it will show you your Apple ID. Its usually the email you used when you created your account
10/6/2021 10:37:40 PM • Apple Cell... • Answered on Oct 06, 2021
2answers
Forgot my passcode for my iPhone 7 without Apple ID
It's stolen then? You can't have an iPhone WITHOUT an Apple ID. It is your link to the phone and your email address. It is difficult to forget a passcode that you use 50 times a day. If for some reason you did, you connect it to your computer with iTunes on it, back it up and then do a Factory Rest. Then you restore the image you had before without the passcode. You are bound to have exceed 4 tries to unlock it, so not it is PUK locked by the Telco that the phone was purchased from. Only they can unlock that part of the puzzle.
9/25/2021 6:28:29 AM • Apple Cell... • Answered on Sep 25, 2021
How to save wi fi password on Apple Iphone5
90c244ace0
8/26/2021 5:37:59 PM • Apple Cell... • Answered on Aug 26, 2021
2answers
IPhone 5S Frozen on apple screen
Maybe need new battery. Consult Apple.
8/20/2021 10:25:27 AM • Apple Cell... • Answered on Aug 20, 2021
3answers
I have somehow deleted my notes from my iPhone 8 and apple have said they were not backed up. I retrieved my notes from my iPad because they were backed up. Can you help?
Actually if the deleted notes on your iPhone 8 are not overwritten, you can use iPhone data recovery software to help you get them back. First use the iPhone data recovery software to help you scan out your iPhone 8 and see if the deleted notes are overwritten or not. Then you can use it to get them back. iPhone Note Recovery How to Restore Deleted Notes from iPhone
6/19/2021 5:17:43 PM • Apple Cell... • Answered on Jun 19, 2021
I have reset my Apple ID password on my Iphone but it dont seem to recognise it on my Macbook pro.
Reset your password by your macbook .It will work then.
4/3/2021 5:39:33 PM • Apple Cell... • Answered on Apr 03, 2021
4answers
How to download free music on iphone 4s
The only way that i am aware of Downloading free music is eihter jail breaking it and going from that direction or by owning the disk and adding them to your itunes from there
2/26/2021 6:31:41 AM • Apple Cell... • Answered on Feb 26, 2021
Do you have software for apple mac computer?
Yes we do, we have lots. What would you like? Click COMMENT under my post and let me know
2/20/2021 5:17:21 AM • Apple Cell... • Answered on Feb 20, 2021
How do you fix a iPhone because mins Judy has the Apple thing on it
I am an Apple Expert, but your question doesn't make sense to me. Click Comment under my post to explain. Who is 'mins Judy', what is 'the Apple thing'?
2/7/2021 12:20:21 AM • Apple Cell... • Answered on Feb 07, 2021
How to reset my apple ID
How to reset your apple or icloud password with your email address or security issue If two factor authentication is not turned on for your Apple ID, you need to change your password by using an email address or answering a security question. 1. Navigate to in any web browser iforgot.apple.com 2. Enter your Apple ID email address. 3. Click continue. 4. Select I need to reset my password. 5. Click continue. 6. Choose to get email or answer security questions. In this example, we will send an email. 7. Click continue. 8. Click finish. 9. Open the email you received from apple. It will be named "how to reset your Apple ID password.". 10. Click Reset now. 11. Enter your new password. 12. Enter again to confirm 13. Click reset password.
1/26/2021 8:26:09 AM • Apple Cell... • Answered on Jan 26, 2021
Apple iPhone 4S 64GB Factory Unlocked Phone White Logo
1 questions posted
Popular Products
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Apple Cell Phones
  • Apple Cell Phones
Most Popular Question
replace battery iphone 4s battery
  • Cell Phones
