20 Most Recent
BenQ DC E30 Digital Camera Questions & Answers
There is no slider on my card
If yo are talking about the slide button that lock and unlock it it is present only on SD cards ..and if you have another one ..( MMS for example there is non ..It looks almost the same but a little shorter and fits the same slot ..If you wanted something else please ask with details ..
Carte mémoire compatible
Sorry my answer is in English, je ne parle pas tr?s bien le Fran?ais. Hopefully you can read English or can get this translated.
First
check that you are using an SD card with a capacity which does not
exceed 2GB as that is the maximum your camera can handle and it will
give error messages with larger capacities, especially if you have
fitted a later specification SDHC card.
If you are using the correct type and capacity of memory card then this
is such a common question that I hope you don't mind if I paste my
generic answer below. Note that cards may appear to be unlocked when
they're not. The answer also covers what to do if the card is faulty.
Your
camera uses SD memory cards. On one edge is a slider switch: towards
the electrical contacts is the unlocked position and away from them is
locked.
Unfortunately, the switch is easy to move accidentally
and it's also easy for it to appear to be unlocked when it isn't. Like
any mechanical component it's also possible for the switch to fail.
If
the switch is in the locked position then slide it fully to the
unlocked position; if it's already in the unlocked position, slide it
fully to the locked position and then fully back again. There should be a
soft click at each end of the switch travel, if not then the switch is
definitely faulty or obstructed.
If that fails, then try looking
closely at the switch in both positions to ensure that there is no
debris obstructing its movement, if not then check the electrical
contacts to ensure that they're completely clean and grease-free. Don't
touch the contacts with your bare skin, but if the contacts need
cleaning then a cotton bud (Q-tip) moistened with a little alcohol or
methylated spirits can be used to clean them.
If you still have
no fix, then try a different SD card as yours may have an irreparable
faulty switch. If the card does prove to be faulty then on most major
brands you may be able to return them to the manufacturer for exchange:
I've found that they will often do this on a goodwill basis even if the
card is out of warranty. Just check the manufacturer's website for support details.
If all options regarding the memory
card are unsuccessful, then you have a faulty camera and further
remedies require either a professional repair or replacement of the
camera.
I hope that my free answer has been of use and has given
you options to fix your problem. Please let me know by taking a brief
moment to rate my
reply.
I used a lot of
Try this first. Take a regular new #2 pencil with an eraser and using said eraser rub all the contact points of the battery compartment. Over time a little oil and corrosion will cause these contacts to act as a resistor and thus the camera thinks the batteries are now dead. Let me know how that works. Hopefully you haven't diposed lots of "good" batteries!
Driver
dear sir
please i want to driver camera benq dc e30 for working on windows xp .
my e- mail is
[email protected]
Camera turn off
dear top Experts.
I have digital camera DC E30 BENQ .I do turn on my camera after seconds turn off.first please help me.secndly for repair my camera I need manual repair. thank you very much
I need help
here is the link for the E30 for Windows XP/Win 2000/98. Download, install and follow the instructions.
http://benq.co.uk/support/downloads/downloads.cfm?product=684&page=downloads&dtype=D
here is the link to the user manual if you need it;
http://benq.co.uk/support/downloads/downloads.cfm?product=684&page=downloads&dtype=M
Please ask again if you have any trouble.
Hope this helps :)
Where can i find an firmwareupdate for benq dc c850
Please.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
Updates are only allowed if the system is working without an error.
If it is not working correct, you can't be sure it will load the update correct and you never know what happens when the update is started.
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
I'm sure there will be no update for the Benq camera.
7/27/2014 4:27:51 PM •
BenQ Cameras
Answered
on Jul 27, 2014
