20 Most Recent
Samsung Galaxy Y Questions & Answers
How to unlock samsung galaxy y for free
hai, you can unlock your Samsung galaxy y by using unlock code. It is easy method don't need Google account to unlock it. you can unlock simply
1 - Switch ON your Samsung Galaxy Y S5360 with a NOT ACCEPTED
SIM Card.2 - Compose : #7465625*638*CODE#
(or *#7465625*638*CODE#
).you can get correct unlock code for your samsung galaxy y at
TheUnlockArena.com
I lost my phone (samsung galaxy y ) i have my imei number , how to block my cell ?
you phone your service provider with your IMEI number the will then put a hold on your phone until it is found the they will remove the hold they have on it, or if you have downloaded a find my phone app u should be able to track it down through your computer i have found both solutions to work as i have done both when i misplaced my galaxy. lookout security is good to use for an android phone. i hope this helps
Samsung galaxy y lock key restarting
Did you drop your device very hard, mess with the software, or opened it, because if you broke your lock key, you will have to send it to samsung to get it repaired, or find a phone repair shop, but it's better to get a new phone.
When it start
Format it using key combination. Home button+volume up and power, hold it tell android logo appears. Do factory default. You can
Force close
Try deleting and re installing apps, may help
Open line samsung galaxy y
Hi visit
Mobileunlocksolutions.com to unlock your Samsung galaxy y mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Gps keeps saying data unavailable ... what can I
This should happen when the phone is not connected to the net or you are holding it such that the GPS antenna is covered by your hand. And also if you are in a covered area. The GPS requires you to be in the open (no clouds either).
Stuck at the logo of samsung galaxy y
Try a reset. Turn the phone off.Hold the following 3 buttons at the same time.- Volume Down- Menu button under your screen- Power buttonThis should bring up a menu with the option to reset your phone.I forget if it's Volume Down or Volume Up.One of them will definitely give you the option to reset.If this does not work it may be an internal memory corruption which I myself experienced. It needs to be sent back to warranty, it took me only 1 week to get my phone back from Samsung when I went to the retail store to return it.
