20 Most Recent Kodak Easyshare C195 14 Mega Pixels Digital Video Camera Questions & Answers
I have a problem putting pictures on my laptop (I have a Kodak Easyshare C195). It used to work fine. I would plug in the camera to laptop, photos would be on the laptop. Now I just get this message:
Hi there There are basically three methods of looking at & copying photos from your camera to your PC. 1. Often, and Kodak certainly do, the camera manufacturer will bundle software with the camera, to ease the transfer of photos. Kodak Easyshare is certainly one of those. I would suggest that you use the CD that came with the camera to re-install the software exactly as you did when you first got the camera. If this does not give you back the transfer yo want you could try these methods. 2. Removing the memory card from your camera and inserting it into the card reader slot on your laptop (most modern laptops have a card reader). It does assume that the card you use in the camera is compatible with your card reader. 3. Connect your camera to the laptop via a USB port with the lead which will have been supplied with the camera. In both cases the camera/card will show up in "My Computer" as a removable drive. Which letter it uses will depend upon the configuration of the computer. Double click on this drive and navigate to the folder holding the photos (probably named "DCIM") which will be files in numerical order with the ".jpg" on the end of the file name. These files can then be cut/paste or copy/paste to an appropriate folder on the computer. Most recent versions of Windows will preview these files when they are double-clicked, or in some cases create a slide show of all of them for you. . I have found this EasyShare Software Help which may have information in it relevant to yourself, I didn't go all through it I also eventually found this Extended User Guide for the C195 here: http://resources.kodak.com/support/pdf/en/manuals/urg01134/C195_xUG_GLB_en.pdf which may be of even more use, especially as this can be saved to your computer for future reference. Hope this helps
12/19/2014 2:48:00 PM • Kodak Easyshare... • Answered on Dec 19, 2014
0answers
Why wont my SD/SDHC card format ?
Sometimes certain cards will save your media to them but won't format. It has to be a SD for the type of software you have.
8/8/2014 2:47:31 AM • Kodak Easyshare... • Answered on Aug 08, 2014
Lines on screen
LG flat screen 50 inch
4/22/2014 10:39:16 PM • Kodak Easyshare... • Answered on Apr 22, 2014
My camera is in spanish & i need instructions in English
Press the MENU button, select the Settings tab, then select the next-to-last item on the menu.
3/17/2014 5:32:06 PM • Kodak Easyshare... • Answered on Mar 17, 2014
I have a c195 camera & its in spanish rather than english
3/17/2014 5:31:42 PM • Kodak Easyshare... • Answered on Mar 17, 2014
Can i increase my pixel size
The three lowest resolutions are 1280x960, 1920x1080, and 2048x1536. To change the picture size see http://resources.kodak.com/support/shtml/en/manuals/urg01134/urg01134c5s1.shtml.If it must be 1200x1200, you can shoot at 2048x1536 and then resize using just about any photo editing program such as Picasa ( http://picasa.google.com ).
7/11/2013 3:41:11 PM • Kodak Easyshare... • Answered on Jul 11, 2013
Can I take clear good pictures of a full moon on a clear night?
You're going to face two separate problems here.One, the moon occupies a rather small portion of the night sky. Even fully zoomed in, the moon is going to be not much more than a bright spot in the sky.Two, the camera is designed to assume that almost every scene is an average brightness. Given how much of the scene is a black sky, the camera will attempt to render the sky as average (what photographers call a "medium gray"). This will result in a picture with a gray sky and a featureless white blob for the moon.If you think about it, the full moon is nothing more than a really big rock under a midday sun. Thus what you want is the same exposure as when taking a picture on a clear sunny day. Unfortunately the camera is going to be fooled by all that dark sky and try to compensate for it. What you really need is to be able to bypass the camera's light meter and set the proper exposure yourself. The C195, unlike more sophisticated cameras, doesn't allow you to do so. Sorry, but that's just the way it is.
3/25/2013 3:11:01 AM • Kodak Easyshare... • Answered on Mar 25, 2013
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
2/18/2013 2:01:13 AM • Kodak Easyshare... • Answered on Feb 18, 2013
Formatted pictures and now they are gone
If the pictures were on a memory card and you haven't done anything with the card since you formatted it, you may have a chance to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the card into a card reader connected to your computer and run the program.
1/27/2013 2:27:52 AM • Kodak Easyshare... • Answered on Jan 27, 2013
Kodak easy share C195 digital camera says the internal memory is full
FORMAT the internal memory using Menu options...
6/22/2012 7:01:10 PM • Kodak Easyshare... • Answered on Jun 22, 2012
My kodak camera takes pictures but wont download to the computer. i never had a problem with until now. what could be the problem?
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
4/30/2012 7:58:44 PM • Kodak Easyshare... • Answered on Apr 30, 2012
0answers
Kodak Easyshare C195 14 Mega Pixels Digital Video Camera Logo
27 questions posted
Top Kodak Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Kodak Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Kodak Video Cameras
  • Kodak Video Cameras
Most Popular Question
clear good pictures full moon clear
  • Video Cameras
