20 Most Recent Fujifilm X10 12 Megapixel-4x Manual Optical Zoom-1080p HD Black Questions & Answers
0answers
ERROR E-2415, 2416, 2418, 2411 FOR FUJI FRONTIER 370 WHAT IS THE ERROR PLEASE REPLY ME
The answer is still the same
2/13/2024 8:00:28 AM • Fuji Cameras • Answered on Feb 13, 2024
2answers
In my fuji frontier 370 error 2503 and w2411 is coming
The "W" indicates that it is a recoverable error. The "24" indicates that there is a problem in the paper feeder. The "25" indicates that it is a laser printer problem. Looks to me as though you have a paper jam.
2/13/2024 7:57:44 AM • Fuji Cameras • Answered on Feb 13, 2024
Replace flash unit FUJI S5700
7/26/2023 1:43:05 AM • Fuji Cameras • Answered on Jul 26, 2023
Sensitive Command Dial on Selector Button.- S9800 Finepix - any ideas what's wrong?
If the command dial on your Fuji Finepix S9800 camera is overly sensitive, making it difficult to select items on the menu or adjust settings, there are a few steps you can try to address the issue:
  1. Clean the dial: Sometimes, dirt or debris can accumulate around the command dial, affecting its sensitivity. Use a soft, lint-free cloth or a small brush to gently clean the area around the dial, removing any particles that may be causing the sensitivity issue.
  2. Adjust the sensitivity settings: Check the camera's menu or settings to see if there are any options to adjust the sensitivity of the command dial. Look for settings related to "dial sensitivity" or "control dial response" and experiment with different levels to find the one that suits your preferences.
  3. Reset the camera settings: If the sensitivity issue persists, you can try resetting the camera settings to their default values. Look for the "Reset" or "Factory Reset" option in the camera's menu and choose the appropriate setting. This will restore the original settings and may help resolve any software-related issues.
  4. Contact customer support: If none of the above steps resolve the sensitivity problem with the command dial, it may be worth contacting Fuji customer support for further assistance. They can provide specific troubleshooting steps or advise you on whether the camera needs to be inspected or repaired by a professional technician.
It's important to handle the camera with care while attempting any adjustments or cleaning. If you are unsure or uncomfortable with the process, it's recommended to seek professional help or take the camera to an authorized service center to avoid any potential damage.
6/18/2023 4:43:48 PM • Fuji Cameras • Answered on Jun 18, 2023
2answers
I have a Fuji finepix Z85 camera, does anyone know the capacity of the internal memory? How much can it take without a memory card?
Hi, Please look on the front cover of the camera's box or it's manual for a number followed by MB or GB and that number should be the answer to your question. And please double check (in the manual) that the camera does have a memory separate from any default sd card that comes with the camera. Thank you.
11/29/2022 4:45:11 AM • Fuji Cameras • Answered on Nov 29, 2022
Focus error
hi i need help with my focus errar
6/21/2020 2:39:51 PM • Fuji Cameras • Answered on Jun 21, 2020
Fuji 370 Error Message W-2649
Sounds interesting - what does it mean ?
12/24/2019 5:31:20 PM • Fuji Cameras • Answered on Dec 24, 2019
How do I turn off the date stamp on a Fuji XP?
Follow the "instructions" in the "manual"
9/19/2019 7:58:14 PM • Fuji Cameras • Answered on Sep 19, 2019
Camera fault
Check batteries and the terminals that connect to your batteries. Often the contacts get corroded because batteries have acid in them.
8/13/2019 10:01:32 PM • Fuji Cameras • Answered on Aug 13, 2019
Where can i buy the 2 motherboards for the fuji S8650
Ebay or Fuji, possibly ?
6/20/2019 9:39:54 PM • Fuji Cameras • Answered on Jun 20, 2019
How can fix evaporation corretion error i-l-p-2662 fuji frontier lp5000
This query does not appear to relate to any model of camera - are you sure you have posted it in the correct forum ?
6/7/2019 4:50:17 AM • Fuji Cameras • Answered on Jun 07, 2019
Why does my fuji s5 pro have dark pics in the auto mode does fine if i shoot manually
Can you re-write your question properly?
3/22/2019 2:50:58 AM • Fuji Cameras • Answered on Mar 22, 2019
Parts manual on Fuji Fine Pix S5700 camera
Simply download it from Fuji website! If that is not possible, google it.
3/22/2019 2:47:27 AM • Fuji Cameras • Answered on Mar 22, 2019
I put a micro memory card into it's adapter and inserted it into my Fuji Finepix S700. Now I can't remove it.
It sounds like maybe one of the pins are broke, I wold try flashlight and magnifying glass to inspect it, If you find one of the mettle contacts on the card is broke it is probably ok to just pull it out firmly it will break the card contacts but I doubt it will harm you camera ~T?M~
2/27/2019 11:01:52 PM • Fuji Cameras • Answered on Feb 27, 2019
3answers
My camera wont show my photos
Is the display blank only after taking pictures, or blank all the time (i.e., can you see the menus)? If you can see the menus, try performing a Reset All (page 67 in the manual). The idea here is to set the contrast/backlighting to factory presets. The manual can be found here. If the display is blank all the time, try holding it near a bright light and look at it from different angles to see if you can see any image on the display (if the backlight isn't working, you may be still able to see items on the display). If that's the case, you may be able to navigate to the menus and perform a Reset All. Otherwise, pull the batteries out and leave them out for a longer period of time - several days, if possible. This should also reset the camera. Failing this, you will likley need to send it in for repair.
12/25/2018 4:18:26 PM • Fuji Cameras • Answered on Dec 25, 2018
Where to locate the Model # on the Fuji Instax mini 7S?
look inside the battery port
11/27/2018 12:20:14 PM • Fuji Cameras • Answered on Nov 27, 2018
Fujifilm X10 12 Megapixel-4x Manual Optical Zoom-1080p HD Black Logo
3 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
Fuji Cameras
  • Fuji Cameras
Most Popular Question
recover lost photos from internal memory
  • Cameras
