20 Most Recent
LG 60PZ550 3D Plasma TV Questions & Answers
Starnge rainbow Grrenish Flickering on LG PLASMA 60PZ550. VIDEOS of Problem!
Hi Jeff,
Contact discount.merchant.com for those parts. I believe they sell both parts. They also have a great customer service line that you can call where they will help you find. I'm thinking of buying a new lamp for my RPTV from (I think I just broke it moving the TV). If you need help with instructions try the fixyourdlp.com/forum -- there is a community of experts there will lots of D.I.Y tips. I used them to figure out a problem I was having with my remote.
Strange rainbow.reenish type effect
Did you notice any better picture when you play a movie on a DVD player or using a flashdrive on this TV? Is the picture quality better? Or is it the same? Try to check another cable connection or try to play TV channel thru internet. The last option in this case is to show a TV mechanic for he would better understand which part to order.
Update firmware
A firmware update should be.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.Firmware update procedure to many brand TVs are given in details, with illustrations.
60pz550 screen replacement.
The first thing you will want to do is get the part # off of your panel. I would then do a google search of that part # to locate a supplier with the panel. Sadly, I'm afraid that you will find that the cost to replace the panel will exceed the price of a new TV.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
