20 Most Recent
Umax Astra 2000U Flatbed Scanner Questions & Answers
Umax astra 5600
http://www.tech2.com/india/reviews/scanners/umax-astra-5600-scanner/959/0
Astra 20000U lost the power
if you can see the voltage and amp requirements either on the machine near where it would plug in or a manual then I have picked up the transformer at radio shack and they have a set of different ends to plug in on the DC side
Download drivers
http://www.opendrivers.com/driver/233307/umax-scanner-astra-5600-5650-driver-windows-98se-me-2000-xp-free-download.html
There is a download of the driver you are looking for on this page above. click the link, save it to your desktop and execute.
Need drivers for umax astra
Hello thanks for using fixya
You can download easily and free driver for your Umax Astra 2000U Flatbed Scanner by clicking on the link given below. Enter verification code & click on download, Next page will open & after 30 secont downloading will start. Download it. After downloading extract the files, Install it on your PC & enjoy
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Click Here to download
I just bought a umax
What OS are you using?
I'll use XP for this,it might work for Vista also.
Go to this link and in the "Notes"section download the Windows XP patch to your computer.
Then go to this link
http://www.driverskit.com/freedownload/Scanner/Umax/Astra_2100U_VistaScan_3_55_USB/14858.html
The 2nd section starts with
You can download driver for Umax Astra 2100U VistaScan 3.55 USB
here"
Click on "here" and you'll download Vistascan 3.55.That will extract folders,the setup file should be in folder #1.
I need install umax astra scan 5650 on windows 7
You either must have the DVD, or buy them from Umax. :(
I would suggest you to download the drivers from the link mentioned below and check whether you can download and install the right drivers.http://www.umax.com/download/index.jspIf you’re unable to find the right drivers, then I would suggest you to contact the manufacturer’s for further assistance.:You must be logged on as an administrator to perform these steps.
1. Open Device Manager by clicking the Start button, clicking Control Panel, clicking System and Security, and then, under System, clicking Device Manager. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2. In the list of hardware categories, find the device that you want to update, and then double-click the device name.
3. Click the Driver tab, click Update Driver, and then follow the instructions. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.For more information, please refer the link mentioned below:http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Windows goes off with the msg 'NTLDR is missing'
NTLDR errors are usually caused by defective RAM on the motherboard. Try removing one of the RAM sticks on your board and see if computer works fine. If still gets error msg, swap the RAM stick and try again to narrow down which stick is faulty. Sometimes, its simply some corrosion on the RAM contacts which in that case, you only need to re-seat the sticks.
Umax astra 5600
This is going to be a setting in your scanner program. The scanner does not have to load in your systray when your computer starts to work. This just makes it respond a couple of seconds quicker, but slows your computer down every time it starts. Never put things in your systray unless you use them constantly. Things by your clock are things that are always running. This slows your computer down.
I
can't fix this for you, but if I helped you get it fixed, please rate it as a
fixya not a helpful rating. These ratings let me be allowed to help you
and others in the future.
