20 Most Recent LG FLATRON W2252TQ-PF 22" LCD Monitor Questions & Answers
Monitor won't power up when connected to power
Possibly the monitor itself has a tripped circuit breaker. Look for a reset button. Might be in a pinhole.
2/2/2018 8:42:23 PM • LG FLATRON... • Answered on Feb 02, 2018
2answers
No puedo encontrar el controlador para windows
english pliz
6/6/2016 6:31:36 AM • LG FLATRON... • Answered on Jun 06, 2016
0answers
W2252tq
Be the first to answer 3/30/2014 4:20:56 AM • LG FLATRON... • Posted on Mar 30, 2014Be the first to answer
0answers
LG
Be the first to answer 3/20/2014 6:10:05 PM • LG FLATRON... • Posted on Mar 20, 2014Be the first to answer
0answers
Monitor degauss
Be the first to answer 1/30/2014 5:26:57 PM • LG FLATRON... • Posted on Jan 30, 2014Be the first to answer
When turn on screen goes out
Capacitors of power supply board in Monitor is bulging or busted. Get is replaced.
12/18/2013 1:11:33 AM • LG FLATRON... • Answered on Dec 18, 2013
Lg flatron screen keeps flickering, if i switch it
sounds like a capacitor in the power supply is going. Check caps and look for bulged or leaking component. Most new devices have non filled caps so you may not be able to judge these by a visual check.
10/7/2013 3:35:31 PM • LG FLATRON... • Answered on Oct 07, 2013
Black horizontal lines across entire screen.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
12/8/2012 9:04:12 AM • LG FLATRON... • Answered on Dec 08, 2012
All white display
Just the white glow and the on screen menu does not show anything either?
If that is the case, the T-CON board on the LCD panel may be bad (blown fuse) or it is not getting the 5vdc/12vdc from the main board, or the ribbon cable came loose. See examples here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
8/11/2011 9:56:35 PM • LG FLATRON... • Answered on Aug 11, 2011
2answers
Power is on but have a red flashing light, I
You need to open LCD case and try to find Power Inverter board. On power inverter board, you can see some of failure caps. Please see picture below for sample of bad capacitor. All failure capacitor must be replace with new capacitor and your LCD will be work fine after that.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
6/30/2011 8:42:50 PM • LG FLATRON... • Answered on Jun 30, 2011
The screen is black and
Try to see if this works on another computer first, if it does, then it assumes the monitor is ok.
Then as the computer boots up, boot to safe mode by pressing F8 and once in that state, set the display to a mode that the graphics card will support.
If none of the full colour options work, the graphics card may be incompatible, try changing the graphics card.
6/13/2011 11:40:34 PM • LG FLATRON... • Answered on Jun 13, 2011
My LG Flatron W2252TQ 22 inch LCD monitor is
Either the power supply or the backlight is going bad. Replacing either will be expensive ... might be better off replacing the monitor.
2/28/2011 8:04:16 PM • LG FLATRON... • Answered on Feb 28, 2011
LG Flatron W2252TQ does not power up. When I turn the PC on, the blue light momentarily turns on before turning orange and then reverting back to grey.
ok try this one switch the hard-drive off and on again to restart it and then the screen would come one.
7/19/2022 10:19:51 PM • LG Flatron... • Answered on Jul 19, 2022
I was cleaning the screen of my lg flatron w2053tp and the screen went black. The power is on and I can bring up the menus but otherwise nothing
Check the all the cables. Check input settings by using the menu.
8/3/2021 7:29:51 AM • LG Flatron... • Answered on Aug 03, 2021
Hey I have an LG Flatron L1718S screen that work fine for a few weeks then suddenly switch off for a few days ,then switch on again,it's a irritating cycle.Please HELP
  • Larry Ng Jul 15, 2021that is just a YEAR 2007 LCD computer monitor, it needs a computer to work. if it fails in a 2nd PC , if that test fails,the monitor is bad. (hardward failure, monitor. the tests are simple, it fails on 2nd good PC, what can be more simple that test ANY 14 year old monitor on a 2nd good PC. when dead do this.(test2) they are all here when dead again use a FLASH LIGHT. (or in UK a low carbon foot print TORCH)<< joking. https://pcdied.com/monitors_and_screens/... all monitors older than 2010 do this . (has CCFL inside and that is never fun now) the cure is newer monitors 2011 to now called LED monitor.s or OLED. the tubes are cold cathode florescent tubes. (back lamps.) (have 5 classic fail symptoms not just dead) they are short lived, laptops and monitors both back then. 20,00hours on the clock and go bad. bank on it. the 3 failures are CCFL, PSU board, and logic board #1 is CCFL the all died long ago, on average about year 2003 (07 +5= 12, 2012) at 20,000 yours boom dead. or intermittent. PSU is here: https://pcdied.com/monitors_and_screens/... below is logic board. one of the 3 fail, CCFL tubes dead is like 99% we retire them if the CCFL test fails. (using bench PSU to test them) but you have non of that so. upgrade
  • Larry Ng Jul 19, 2021 logic board. (CCFL tubes dead, PSU dead, or logic board dead) and or thermally failing , and bad.
  • Anonymous Jul 23, 2021 99% of all monitors are all dead. due to those silly low live CCFL back lamps. or the 2cards inside that can fail too. PSU card +HV CCLF power or the Data card is dead. 99.9% of folks seen these facts, upgrade now. high voltage inside 600v on the CCFL pins
7/23/2021 3:55:07 PM • LG Flatron... • Answered on Jul 23, 2021
LG FLATRON W2252TQ-PF 22" LCD Monitor Logo
24 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
power but red flashing light
  • Computers & Internet
