20 Most Recent
Memorex MT1194 19" TV Questions & Answers
Remote codes
026,029,021.
Check these codes. If
you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many
popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy
I need code
Setup codes for Memorex TV are: 0004 0009 0049 0051 0135 0031 0000 0268 0310 0001
Tv remote needed
The most inexpensive solution, is to buy a universal remote. I own a One-for-All universal remote (model URC-4220) which works with Memorex TVs. I bought it at Walmart for less than 10 dollars.
If you want to pay a little more money, here are a few websites to visit: REMOTES.COM 1-800-REMOTES
MRREMOTECONTROLS.COM 1-800-221-1471
You can find a few more websites by typing in:
MEMOREX TV REMOTES into the Google searchbox.
Hope these suggestions help you out. Please take a moment to rate the info I have provided, but using the rating system below. Thanks.
Problem with old TV
The channel is almost always 3 or 4. Be sure you have the VCR connections correct. Just hook up the TV and VCR alone to start with and try both the VCR and DVD. Also the output of the VCR should show a blue screen.
S-Audio Port doesn't work anymore.
Faulty cable, or the solder joint on the rear of the RCA connectors inside the TV has cracked.
This is a common problem and is caused from repetitive plugging/unplugging cables into the connectors, especially if they are not handled very carefully.
If this is the problem, it's a simple solder job. The difficulty is often having to remove the entire chassis to get to it.
A simple alternative is to use a 3-4 way AV selector switch, plugged into the rear AV inputs, leaving the PS2 permanently connected (and other AV devices) then all you need to do is change the switch over to use your desired device.
They are also available with a remote control.
Hope this helps
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
