20 Most Recent
Olympus X920 Digital Camera Questions & Answers
Olympus X-920 camera lens fails
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But,
here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
I am a nail technician.
The closer you zoom the more sensative your camera becomes, I suggest you to use a tripod and take your pictures in a well lit area. You can also use the timer feature on the camera along with the tripod, this way you are not touching the camera when the picture is taken, this will reduce the blurryness on your pictures.
How do i delete photos?
Come on dude, the button on the back of the camera with the icon that looks like a garbage can is the delete button. Good luck
7/29/2014 6:28:36 AM •
Olympus X...
Answered
on Jul 29, 2014
I cant install my vg 165
Before you can work with a camera connected to the PC, you have to install the software that came with the camera. That is a driver, and software you you can get the pictures from your camera to the PC and most of the time that software allows you to edit the pictures a little.
The software is on the CD that came with the camera. If you lost your CD, but you have registered the camera with Olympus, most of the time they allow you to get the software from their site.
1/2/2014 10:20:47 PM •
Olympus X...
Answered
on Jan 02, 2014
Computer does not recognize the Olympus X-940 camera
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
1/25/2012 7:23:45 PM •
Olympus X...
Answered
on Jan 25, 2012
My Olympus VR-340 is not working.
Locate the reset button on your camera, usually found in the battery compartment. Press and hold the reset button for a few seconds, then release it. This action may help resolve any software glitches causing the issue. myreminiapk.com
