20 Most Recent
Panasonic SC-AK200 CD Shelf System Questions & Answers
SA AK200 does not appear to turn off completely
HiFi system actually turned Off when you press power button and display of hello, heavy, vocal etc is demo mode of this system and it activates when unit goes to power off.
You can change its settings like not to show demo mode etc and this procedure is described in owner's manual.
Thank you.
12/25/2016 1:28:13 PM •
Panasonic...
Answered
on Dec 25, 2016
My sound system, the panasonic
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
7/2/2011 4:39:54 PM •
Panasonic...
Answered
on Jul 02, 2011
Disk changer won't stay in
the mechanical disc loader inside is probably damaged. Depending on how much damage was done, you can probably open it up and fix it yourself.
4/10/2009 5:42:14 PM •
Panasonic...
Answered
on Apr 10, 2009
Switching off of SA-AK-37 Music system
Do you have the manual, I think panasonic put some of there fault codes in the back.
Seems to have lots of people saying it could possibly be a power supply fault, an amp fault or shorted speakers.. Some people have gone to the extreme of actually buying new components and trying to unsolder and resolder to try to fix it themselfs.
Try contacting Panasonic, they will be able to advise you better ot possibly repair / replace the system.
1/31/2009 2:28:42 AM •
Panasonic...
Answered
on Jan 31, 2009
Remote problem
dear friend:after apply fresh and new battery and install it in right direction bring an normal radio set -put it in am postion tune dial in position between channel and press power button in remote many times you will hear clicks eash time you press the button if you hear the clicks clearly the problem will be in the player .
2/24/2008 10:01:25 PM •
Panasonic...
Answered
on Feb 24, 2008
I have a panasonic sa vk880 and it wont give sound outputs, when i click on subwoofer button or surrounded enhancer it says error, please help
Try disconnecting all of the speakers except the left and right main speakers. If it works, check the wiring at the back of each speaker to make sure there aren't any shorts between the terminals. Better yet, just inspect the terminals both at the audio unit and the backs of the speakers. Stray strands of wire reaching across to the other terminal or exposed wire on the other side are a common problem.
If you have that all cleaned up and still have the error, you may have shorted transistors in the output amp of one of the channels, very likely the subwoofer. This may be caused by shorted speaker wiring, or the amp may have failed on its own. In either case, you would have to replace both of the output transistors for that channel (they may be built into a power amp module, in which case the module must be replaced). This requires soldering skill, and the knowledge to identify the transistors and check them with an ohmmeter. Most of the time, it's a basic job for any skilled electronic technician. (I did run into one model that would have required two days of disassembly labor just to get at the failed transistors - I told the customer that wasn't designed for service and he would be better off buying something different to replace it.)
