20 Most Recent
Sylvania 6615LE LCD HDTV Questions & Answers
Will this tv work with an antenna or does it need
All LCD tv's made in the last 10 years support digital tv out of the box and do not need a converter box. However if you want to pick up local stations over the air, you may need an external antenna. Otherwise if you have cable tv or other services, you can connect your service to your tv directly.
You may also want to call your service provider (if applicable) if you have issues connecting it to your tv.
TV turns off
Fixed it !!! Used the approach by Guest; replaced both of the capacitors with 0.1 microfared caps from Ratshack. It's been working for two days. Thanks Guest.
Rabbit ear hook up how do you program the tv to
use your tv remote and click menu, then click setting, or "TV" if tv is an option. choose "channels" or something of that nature, then run a channel scan. if you're using bunny ears, set the option under channel search to "air". hope it works out for ya! :)
TV TURNS ON BUT THEN
hi....luckily your TV isn't totally scrap...it has no shorted wires or blown fuse....the problem is coming from the power supply section.....if you can check it out..try to look for bloated or bulgy capacitor....if you see one or two..replace it w/ same value...mostly electrolytic type...test run after replacing...good day..
Tv wont stay on....
the answer is here in FixYa:
http://www.fixya.com/support/t123497-tv_turns_off
Same as above
please check the battery of your remote, that the main cause your problem.
