20 Most Recent Sylvania 6727FDE 27 in. TV/VCR/DVD Combo Questions & Answers
4answers
Directv universal remote
ok i have a sylvania tv/vcr combo, similar problem, here's how i got the directv remote (RC23 & RC32) to operate basic t.v. functions:
-First i found the code that worked for the vcr (20000 in my case).
-i programmed "AV1" to 20000, this allowed me to power the tv on/off, change the channels but not operate the volume, so...
-after plugging in the 20000 code (with the slelector switch on AV1 still):
1. Press and hold the MUTE and SELECT keys until the
green light under the TV position flashes twice, then
release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press select
that allowed me to operate the t.v. volume from the remote w/ the selector switch in any position, the only thing is i have to switch to AV1 in order to power off the T.v.
hope this helps in your case
6/2/2010 5:47:38 PM • Sylvania 6727FDE... • Answered on Jun 02, 2010
Sylvania 27 in. tv/vcr/dvd combo remote code
Made by Funai. Try Funai codes.
5/16/2010 4:25:54 AM • Sylvania 6727FDE... • Answered on May 16, 2010
2answers
TV Dilemma
you have a stuck vhs tape in it.
3/10/2009 3:38:41 AM • Sylvania 6727FDE... • Answered on Mar 10, 2009
find out who sales sylvania, look at what other tv they sale and try there codes. sears is good for this to. I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
1/19/2009 10:41:42 PM • Sylvania 6727FDE... • Answered on Jan 19, 2009
Sylvanis tv vcr dvd combo
It sounds like the VCR mode switch is dirty. This is located on the PCB, underneath the right hand side of the VCR mechanism. If you do not know what you are doing, I do not recommend trying to clean it yourself. You have to remove the VCR from the board, and pop the wheel off the top of the switch. Use a cotton swab with a bit of alcohol to clean it, and then put a dab of WD-40 on it. Good luck. Also, you might want to tryt to reset the VCR mechanism to the fully ejected position if it is not there already.
11/5/2008 1:40:32 PM • Sylvania 6727FDE... • Answered on Nov 05, 2008
No sound on model 6727FDE
Get a new TV
6/1/2008 11:14:00 PM • Sylvania 6727FDE... • Answered on Jun 01, 2008
Sylvania 6727fde universal remote code
Hello goyitos,
I would contact the TV manufacture and then see if they can send you a replacement remote. They will usually do this for the cost of the remote with shipping and handling.
I hope this helps
Thank you,
Shuttle83
3/24/2008 8:55:11 PM • Sylvania 6727FDE... • Answered on Mar 24, 2008
TV help
if they have a menu button on the tv push it .
if they dont then the remote is the way in I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
1/7/2008 10:25:59 AM • Sylvania 6727FDE... • Answered on Jan 07, 2008
Is it possible to cast/mirror/ etc. from ab android phone to a Sylvania TV manufactured in 2005?
No, because screen casting wasn't invented and it isn't a Smart television. Time for a new one.
3/11/2024 8:53:32 PM • Sylvania... • Answered on Mar 11, 2024
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work. Let's troubleshoot the issue and try to get it working: If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why. Check Power Cord and Connections: First, ensure that the power cord is securely plugged into both the TV and the electrical outlet. If you suspect a faulty power cord, consider trying a different one. Reset the TV: While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset: Unplug the TV's AC adapter from the electrical socket. Press and hold the Power button on the TV for 20 seconds. Plug the AC adapter back in and turn on the TV. Check Audio/Video Cables: Inspect the audio/video cables connecting your TV to the satellite or cable receiver. Ensure that the color-coded prongs match their respective connecting points. Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs. Inspect Coaxial Cable: Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN. Confirm that the connection is firm; a loose coaxial connection can cause display issues. Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure. Check for Interference: If distortion continues on the TV screen, consider nearby interference. Power-hungry appliances can cause electronic interference, affecting display quality. Visit a Repair Shop: If the above steps don't resolve the issue, you may need professional help. Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering. If uncomfortable with such tasks, consider visiting a repair shop
2/3/2024 6:17:20 AM • Sylvania... • Answered on Feb 03, 2024
2answers
I have a 37in limited edition Sylvania TV I have tried every code on my Phillips universal remote none work. Is there a specific code.
  1. Auto Code Search:
    • Turn on your Sylvania TV.
    • Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
    • Press the "TV" button on the remote to set it to control the TV.
    • Press the "Power" button repeatedly until the TV turns off.
    • Press the "OK" or "Enter" button to save the code.
  2. Manual Code Entry:
    • Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
    • Press and hold the "Code Search" button on the remote until the indicator light stays on.
    • Enter the code using the number buttons on the remote.
    • Test if the remote now controls your TV. If not, repeat the process with a different code.
  3. Try Common Codes:
    • Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
1/9/2024 10:32:14 PM • Sylvania... • Answered on Jan 09, 2024
Sylvania tv with vcr/dvd player. vcr tape keep being ejected even when using tape cleanser ejected
The most likely cause is a faulty mode switch.
12/12/2023 10:12:41 PM • Sylvania... • Answered on Dec 12, 2023
2answers
Flashing colors on Sylvania lcd TV
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
11/5/2023 2:26:58 AM • Sylvania... • Answered on Nov 05, 2023
Why no tv picture on my Sylvania #ssc092 ac/dc tv/vcr combo?
it is a very simple TV, is TV connected to cable? Here is link to manual copy and past download and save for future reference. It is very old and has CRT not LCD. https://www.manualslib.com/manual/776815/Sylvania-Sylvania-Ssc092.html#manual
10/20/2023 4:15:16 PM • Sylvania... • Answered on Oct 20, 2023
Sylvania tv screen went black last night when we hit a channel button on remote
More likely you hit the Source / Input button and lost the signal. Press it again until it comes back.
9/13/2023 4:08:17 AM • Sylvania... • Answered on Sep 13, 2023
Codes for a Sylvania 32'tv
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 4-Digit Sylvania TV Codes for Universal Remote
  • 0002.
  • 0008.
  • 0030.
  • 0054.
  • 0068.
  • 0096.
  • 0171.
  • 0321.
More items... • Jan 1, 2023
RCA Universal Remote Codes For Sylvania TV - GenTwenty
6/22/2023 5:33:00 AM • Sylvania... • Answered on Jun 22, 2023
How can I unlock my PIN# on my sylvania smart tablet, and DVD 10.1.
By typing the correct pin or activating a factory reset.
6/17/2023 8:57:49 PM • Sylvania... • Answered on Jun 17, 2023
Does sylvania LC260SS2 support earc/arc with the hdmi inputs?
The Sylvania LC260SS2 has a eArc option called fun-Link. This only works with other fun-Link compatible devices. See https://www.manualslib.com/manual/325827/Sylvania-Lc260ss2.html?page=14#manual . (Sylvania TVs are made by Funai Electric.) It may not work with non-Funai electronics. I hope this helps. Cindy Wells
4/25/2023 10:32:56 PM • Sylvania... • Answered on Apr 25, 2023
Sylvania 6727FDE 27 in. TV/VCR/DVD Combo Logo
15 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
sylvania 27 in tv vcr dvd combo remote
  • Televison & Video
