20 Most Recent Kobian Mercury 3.1 Deluxe Classic Digital Camera Questions & Answers
My camera doesn't work with certain memory card,,,WHY?
maybee you are using higher capacity memory cards. pls. check / refer to your user manual regarding supported memory cards for this model . i know this is an old model so usually it only supports up to 2GB of memory card
8/23/2014 3:18:20 AM • Kobian Mercury... • Answered on Aug 23, 2014
7answers
USB Driver for Mercury Deluxe Classic Camera 2.1
i not have drive of MERCURY (deluxe classic Cam) 2.1 mp
please if have send to ([email protected])
3/26/2014 4:44:42 PM • Kobian Mercury... • Answered on Mar 26, 2014
0answers
Webcam driver
Click start control panel-view devices and printers. You should see your webcam from there.If you have trouble with your webcam:Click start control panel-administrative tools-computer management-device manager-scroll down imagedevices you could see a yellow question mark ?right click to reinstall drivers or update driver xp.Click start right click oncomputer select properties device manager scroll to image devices expand rightclick to update driver in W7http://download.cnet.com/2000-20_4.htmlon the home page you shouldsee a search tab just type in what you are looking for IE:webcam name webcam driver you might have to try a few times to get it rightsoftware if you don\'t have the driver you will need to download one here rather doing a driver hunt, which can take hours. http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.htmlWindows XP/Vista/7/8It might take some time being a freeware driver solution.note: It will find all of your outdated drivers.This is a free driver solutions.This will automatically search for and find the correct driver.You will have to update every driver individually once you update. You might beasked whether you want to restart or make a system restore. Point click no to both of these, then continue updating each driver free, then restart once all of the drivers have been updated.Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But it doesn\'t hurt to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, includingwebcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c Windows Vista: DirectX 10).http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computerIf you still have no webcam installed, Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box andthen click "Next."Choose whether you want Windows to search for the webcamdevice driver using Windows Update over the Internet, or if you\'d prefer tohave the device manager search for the driver using a disc supplied by yourlaptop manufacturer. Most drivers can be found on the system recovery discincluded with your laptop, if you choose to add the driver from the provided disc.Place a check in the box next to your choice and then click "Next" to continue.Wait while Windows searches from the driver using WindowsUpdate, if this was your choice. An active Internet connection is required for Windows tosuccessfully do this. Allow the computer to install the driver and then rebootthe system for the webcam to become recognized by the system.Otherwise, you can use the system recovery disc or a driverdownloaded directly from your laptop manufacturer to install the driver withoutusing the Windows Update search feature.Open the CD/DVD-ROM drive and insert the system recoverydisc, or place the driver downloaded from the manufacturer in an easilyaccessed file directory on your PC, such as on the desktop, or in your "MyDocuments" folder.Choose the option "Install the software automatically(Recommended)" in the "Add a device" application, and press"Next" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc andinstall the driver automatically. Press "Finish" to close the wizardand then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually"in order to browse to the driver location where you saved the driver andinstall it from there. Use the opened file manager and locate the driver. Click the "Next" button to install thedriver, then reboot the computer to add webcam functionality.
5/21/2013 9:25:41 AM • Kobian Mercury... • Answered on May 21, 2013
2answers
I need driver for my
7/26/2012 12:42:59 PM • Kobian Mercury... • Answered on Jul 26, 2012
Mercury Cyberpix S590Y Driver
Go to www.driverguide.com search for "Cyberpix S590Y" . The search will yield one result. Click on the link,this will take you to another page, then click the large green Download button. A Captcha request will appear, fill it out and then press the green download button again. Your drivers will download shortly thereafter.
10/12/2011 4:05:55 AM • Kobian Mercury... • Answered on Oct 12, 2011
0answers
My camera the mercury cyberpix 2-210s only take 20
Your Mercury Cyberpix S-210S has an internal memory of 16MB and can be expanded using an SD/MMC Card up to 512MB.Since the picture you capture using this 2 Megapixel camera has an approximate resolution of 1600*1200 and a size of approximately 400kB you can store only around 18 to 20 photos in an 8MB Memory Card.So if you want to store more pictures you have to insert a Memory Card of bigger capacity.Remember the maximum Memory Card capacity supported on your camera is 512MB.Thanks for choosing Fixya.
6/19/2011 4:44:03 PM • Kobian Mercury... • Answered on Jun 19, 2011
Driver download
2/12/2011 3:19:04 PM • Kobian Mercury... • Answered on Feb 12, 2011
Need drivers for win xp
2/12/2011 3:18:41 PM • Kobian Mercury... • Answered on Feb 12, 2011
Mercury digital camra driver
2/12/2011 3:17:52 PM • Kobian Mercury... • Answered on Feb 12, 2011
I need to down load
2/12/2011 3:16:07 PM • Kobian Mercury... • Answered on Feb 12, 2011
If you have the driver of deluxe classic cam 2.1,
i have the driver but ill only give it to you if u give me the money.
1/26/2011 2:47:18 PM • Kobian Mercury... • Answered on Jan 26, 2011
Kobian Mercury 3.1 Deluxe Classic Digital Camera Logo
59 questions posted
Top Kobian Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Kobian Camera Expert? Answer questions, earn points and help others
View Most Popular
Mercury Kobian
  • Mercury Kobian
Most Popular Question
usb driver mercury deluxe classic camera
  • Cameras
