I don't know if this is you first film camera or if you've owned one for years - so pardon some beginner suggestion.
If there's film in the camera, you may have reached the end of the roll. What you're describing sounds very much like this is the case. There is a window to indicate of how many exposures have been taken next to the film advance lever. Most 35mm film manufacturers offer 12, 24 and 36 exposure rolls. Check to see the number shown in the window. If at the end of the roll, you may have advanced the film so far that the number is half in the display and half blocked.
If there is film in the camera and since it will no longer allow any more exposures, you'll need to remove the film. Locate and press the
R button next to the film advance lever. Unfold the crank handle from the knob on the top of the left side of the camera (as viewed from behind - in picture taking position). Twist the crank in a clockwise direction (viewed from above) to rewind the film into the film canister. As you get closer to the end of the film, more resistance will be felt until finally, the handle spins freely. This indicates that all the film has been safely rewound and stored in the canister. Next, lift the knob that the crank attached to up and away from the camera body. The back door of the camera should pop open. You can now remove the film from the camera and have prints made from it.
You can get a copy of the manual for your camera
here. There is no charge to download it - but a donation is accepted by the person that is making it available.
I hope this helps and good luck! Please rate my reply - thank you.
