20 Most Recent
LG GH22NP21 DVD-Writer - Internal Double-layer - DVD-RAM/ R/ RW - 22x 8x 16x (DVD) - 48x 32x 48x (CD... Burner Questions & Answers
Download driver gh22np21
you might have to physically unplug the leads for this
cd/dvd then plug them back this should activate the found new hardware
wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
http://download.cnet.com/lg-gce-8520b-firmware/3000-2122_4-10203021.htmlThe new firmware offers enhanced recording speed of some CD-R
media on your LG GCE-8520B CD-R/CD-RW
I have dvd /rw model
if it is internal cd drive it actualy auto detect on the computer, you can see it on my computer all you need to install is the software for burning
CAN I WRITE AUDIO CD
yes, you can write it in 1x or even 42x if you want. The only thing that can happen is a chance of data loss but not quality. Also some older stereos could run into issues not just cuase of the write speed but cd incompatibilitiy. Audio CDs are nothing more than WAV files written on a CD and then a table of contents added as a CDFS file system.
Burner slows when writing. takes
make sure your cd/dvd burner is getting consistent power test all of the leads that attach including electrical to your cd/dvd burner make sure the connections are good and dust free or just replace they might be faulty
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Hi!
I need driver for GH22NP21
hope this helps
I need the driver of
you might have to physically unplug the leads for this dvd rw then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll to cd/dvd drives + expand you could see a yellow eclamation mark ! or yellow question mark or a red x any of these you need to update the driver right click select update driver
hope this helps
Hola, mi quemador dvd modelo
Los quemadores de DVD cuentan con dos unidades de laser. Un laser es para quemar y leer discos DVD. El otro es para leer discos CD. Es muy común que el uno o el otro falla. Si el aparato todavía está bajo la garantía, puede Ud. pedirles quemador nuevo. Si no, tal vez haya llegado la hora de comprar un nuevo. Lo bueno es ya no cuestan mucho... meno de $30 por quemador de buena marca.
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Lg super multi securdisc driver
Optical drives (at least all modern one's) do not require a driver when run in a Windows environment. The OS provides the support automatically. Is the drive shown/listed in My Computer?
Drivers needed
available here http://www.driverscape.com/download/hl-dt-st-dvdram-gh24ls50-ata-device
