20 Most Recent
Nvidia GeForce4 MX 440, (64 MB) Graphic Card Questions & Answers
I can't find driver geoforce2
There isn't one since this card is just DX7 compatible and Win 7 needs a card that is at least DX9.2 capable.
Get a new video card, a cheap one will cost you less than $25. One like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=365497&CatId=318
Need new graphic card but
Hello.
The best solution for your graphic card replacement is, in my oppinion, ASUS ATI RADEON 9550 GE.
It is 128-bit series model, and it is better with 128MB of memory, because with 256MB is much more expensive, but almost no difference.
Best wishes,
SteveTM
The resolution on screen is blurred even though
http://www.nvidia.com/object/winxp_2k_93.71_2.html
this is the most up to date driver they have available for your graphics card at the moment via geforce if for some reason this does not solve your problem it may be as simple as making sure the resolution you have it config for is available on your monitors spec a good idea would be to google prime res settings for your monitor and finding what is suggested if its a more recent problem though hopefully the drivers will fix it for you
Hope I helped
please leave feedback
Thanks
Robb
I updated my Nividia GX4 graphic card through the
well u have to uninstall the Display driver and then reinstall the old one that was working but ist fix the windows in repair mode while installing windows. some of the files are been updated that wont allow the driver to work. fixing the windows in repair allow you to load the old files again automatically.
I have 2 game problems:
For the graphics card try the following:
Download the latest drivers from Nvidia website & install
If that fails then try completely uninstalling the graphics card & allow windows to find it & install its own drivers.
If that fails check you dont have an onboard graphics card on your motherboard, if you do, disable it in the Device Manager & also your bios (if you know how, if not, dont worry about the bios)
Failing all this you may need more advanced help to check the card is installed in the slot on the motherboard properly or enabled in the bios
though...if you can use it and it is working ok except failing for games, check it meets the games' minimum spec requirements and that the drivers are correct. Hope this helps.
Cant help with the game cheats though...google that :)
I can't find Geforce 2 MX 400 driver for Windows
Search on nvidia web site. Try to download the latest drivers for your video card. Or, the second solution is to check for updates in windows 7, and if your video card is supported you will receive an patch for it from microsoft.
I have a video card nvidia geFORCE2 MX/MX400,. the
Code 10. If the device has a FailReasonString value in its hardware key, that string is displayed as the
error message. The driver or enumerator puts this
...support.microsoft.com/kb/310123 -
Similar
you can see more and how to correct it here above.
