20 Most Recent
Matrix Audio D4t Delta 4 Zone Amplifier Am/fm Tuner Questions & Answers
No keypads detected
Hi when this occurs it is usually a fault on the I squared bus? and is also usually associated with a microprocessor problem too. it is NOT DIYable. Accordingly it needs to be repaired, this should only be done by a professional. To this end what you should do to get the best possible results, is to contact the manufacturers local or head office, and ask them for a referral to an authorised service center, then take the unit there and when in face to face contact simply ONLY ask for a "Quote" as to prospective costings, and go from there, this way you can at least make up your mind as to repair or replace?
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
How can I reset my floureon h 264?
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
