20 Most Recent
Lite On LightScribe (HP640VI) (HP640VI) Burner Questions & Answers
Lg cd ver 1.04
what sort of problems are you having ?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps you
12/27/2011 9:53:32 PM •
Lite On...
Answered
on Dec 27, 2011
I have no manual for
Most DVD burners require a power cable as well as a USB cable. Check the slots on the back to be sure, check for any holes that are round with a pin in the middle, or possibly three different holes in some cases. If you see a slot like that, you need your power cable.
5/4/2011 9:30:20 PM •
Lite On...
Answered
on May 04, 2011
I dont know where is
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
then
click start all programs open windows explorer click on my computer you should see your usb device navigate to the audio files the select the audio files right click copy and then paste them into your computer or select all media files click and hold the cursor and drag and drop them into usb divice or right click and select send to you your usb device hope this helps
1/20/2011 8:23:05 AM •
Lite On...
Answered
on Jan 20, 2011
How do I find out which version of light scribe is
hi right click the light scribe icon, then go to properties then click find location, look for the light scribe icon in the folder , then right click that then properties, and view the version...hope that helps
7/1/2010 9:32:26 PM •
Lite On...
Answered
on Jul 01, 2010
Can I connect this device to a Mac computer or is
You should be able to connect every Optical drive to mac and i guess you can fit it in, becuase both mac and windows ,and linux are using same hardware systems, just in different connections.
Please
rate my solution! =)
Sincerely
Aleksandar Adzic
4/16/2010 7:09:58 PM •
Lite On...
Answered
on Apr 16, 2010
Need a operators manual
Dear sir
in fact i diged out the internet searching for the manual that you mentioned above but nothing i got ... but there is a good point i found the HP640V manual on the address http://search.hp.com/query.html?sh=1&charset=UTF-8&la=en&qt=HP%20dvd640v%20DVD%20Writer%20640%20vi
and you can open a similar product catalog to find out the answer
for your questions .... from the sit www.HP.com
thank you and good luck
12/23/2009 12:34:04 AM •
Lite On...
Answered
on Dec 23, 2009
How do I activate the option to burn an 8.5GB
That option would be set in Roxio, not the drive itself.
Make sure that your machine meets the requirement for speed and memory required to write DVD's at this density.
12/22/2009 6:09:50 AM •
Lite On...
Answered
on Dec 22, 2009
I want to move old HDD drive from broken down LiteOn 5045A DVD recorder to replacement DVD recorder machine...
cart before horse.!WELL BAD NEWS (TOPIC) HDD.the drive is 21 years old tech. 2001it is not any kind of modern standard HDDit is PATA(IDE) NOT MODERN SATA (SERIAL ATA)SO ONLY RELIC OLD DRIVES CAN WORK HERE.or run old 20+ hdd tests that take a week to finish(now you see why SATA was born, PATA stinks)and worst is the DVD burner is not a desktop or laptop standard drive and worse yet PATA againthe old DVD drive, replacement can be hard.lite-on does not support old things, gee most makers do not after 17 year old.also read here, and see how spare parts actually workin this old burner systemhttps://forum.videohelp.com/threads/325208-Liteon-LVW-5045-replace-DVD-drive-project-startedwhat your are attempting is not easythe huge problem is fireware in the devicemany not allow larger HDD over 160GB new.or may not allow all makers of the drive to work at all.is not that DVD DRIVE, PATA DRIVE, NOW 100% OBSOLETETHE SAME FIRMWARE RESTRICTIONS (NOT DOCUMENTED ON EARTH i MIGHT ADD) WILL NOT ALLOW SOME DVD DRIVES BY OTHER MAKES.... LOOKING NOW AT OTHER WORKING ON THIS OLD BEAST WHAT DO I SEE IN their nice PHOTOSL (tech eyes win)the hdd iS NOT SATA IT IS 20 YEAR OLD PATA(IDE) JUNK.FINDING GOOD USED PATA DRIVES IS HARD..NEW ONES ARE SOLD AT SCAPLERS PRICES, (AS expected)the DVD drive is clearly custom made by SONy for Liteon..HERE IS DVD PROOF OF NON STANDARD DRIVE(FIT)
5/15/2022 11:40:43 AM •
Lite On...
Answered
on May 15, 2022
