20 Most Recent Craig CMP748 TABLET GOOGLE CERTIFIED 7 INCH COLOR CAPACITIVE Questions & Answers
0answers
Bluetooth speaker will not connect
Does your computer have bluetooth and is it enabled?
3/19/2014 5:26:42 AM • Computers &... • Answered on Mar 19, 2014
0answers
It will not connect to my windows 7 laptop
Can you add it via "Hardware and Sound?" Click start, go to Control panel, Click hardware and sound. Under "Devices and Printers" there is the option to "add a device," Try adding it there. Does this help? Let us know. Ponder/Meditate/Pray for Peace. Mary Oliveau { hugs }
1/24/2014 3:09:26 AM • Craig Computers... • Answered on Jan 24, 2014
Select, copy snd paste objects
I assume you want to know how to copy and paste??? To select click and drag the curser over the item you wish to copy (it will change to a different color) with the curser still in the colored bit RIGHT click your mouse, scroll down to COPY. Move your curser to where you wish to put your copied bit, RIGHT click and scroll down to PASTE. Viola!
12/21/2013 1:55:38 PM • Craig Computers... • Answered on Dec 21, 2013
Mouse doesn't work
yes they do
12/10/2013 1:40:38 AM • Computers &... • Answered on Dec 10, 2013
Setting account
What OS are you using?
3/24/2013 4:17:07 PM • Craig Computers... • Answered on Mar 24, 2013
Cannot get wifi connection on my netbook
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator. 1. Click Start, type services.msc and hit enter. 2. Locate WLAN AutoConfig service, double click on it to open its properties window. 3. Under General tab, change the Startup type to Automatic and click Start button. 4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
2/19/2013 10:35:31 PM • Craig Computers... • Answered on Feb 19, 2013
Camera
Step 1: The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image. Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
2/7/2013 10:06:30 PM • Craig Computers... • Answered on Feb 07, 2013
2answers
My craig tablet keeps coming
Low memory for android process. Update slideme from www.slideme.org and then install eveything on the micro sd. Let the tablet memory free for process. I know this because a got the same tablet with the same problemm until this. First return the tablet to factory default
1/19/2013 10:20:24 AM • Craig Computers... • Answered on Jan 19, 2013
Can't find driver to read
Hello!
If YOU Looking for Driver , here is
a web site that lets you scan your computer and automatically display the different systems drivers compatible.
Just launch detection and follow the instruction
http://www.touslesdrivers.com/index.php?v_page=29
thank you for choosing Fixya
5/25/2011 2:31:19 AM • Craig Computers... • Answered on May 25, 2011
Craig CMP748 TABLET GOOGLE CERTIFIED 7 INCH COLOR CAPACITIVE Logo
1 questions posted
Top Craig Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Craig Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Craig Computers & Internet
Most Popular Question
forgot password
  • Computers & Internet
