20 Most Recent Toshiba 42H83 42" Rear Projection HDTV-Ready Television Questions & Answers
My toshiba 42h83 tv is dead. It won't turn on. I
hello if you've never looked inside a tv before then you'll be wasting your time with out the right equipment it will be hard. get quote from an engineer good luck
regards
shaun
11/17/2021 8:00:04 PM • Toshiba 42H83... • Answered on Nov 17, 2021
0answers
Toshiba 50h13 hyperboard
You need part #23148024.  The part is NLA.  I have 1 in stock or you can send yours to PTS electronics 800-844-7871 for rebuild. I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
8/16/2012 1:48:48 AM • Toshiba 42H83... • Answered on Aug 16, 2012
My tv recently started to look like its in 3d, i was told about chips...can i do this my self?
msy need some fish the chips can blow if you touch them
8/2/2012 2:48:38 AM • Toshiba 42H83... • Answered on Aug 02, 2012
My toshiba 42h83 tv has sound but no picture
of course check different inputs etc to make sure something did not get disconnected.This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.No simple answer as a lot of different parts are possible for this problem.
4/28/2012 2:31:56 PM • Toshiba 42H83... • Answered on Apr 28, 2012
My Toshiba 65H81 won't turn on only flashing red light on the on button
This question with slightly different wording is listed here 2 times--see my previous answer.
3/21/2012 3:25:35 PM • Toshiba 42H83... • Answered on Mar 21, 2012
I bought my rear projection
Download manual from internet and see (can't remember your PIN code)
11/22/2011 4:44:32 PM • Toshiba 42H83... • Answered on Nov 22, 2011
I have a Toshiba 42H83.
If you just moved it is very possible that you had some week solder break loose at your convergence IC. Reflow the solder on all pins and see if that does not fix your problem.
7/15/2011 8:14:44 PM • Toshiba 42H83... • Answered on Jul 15, 2011
Can we seperate the tv
You should be able to take the screen off and the top black plastic shroud that holds the mirror off to transport it.
1) To do this, you will pull the speaker grill cover off on the front bottom.
2) I think there are four screws at the bottom of the screen holding the bottom in place. Use a 1/4" socket.
3) Disconnect the wire harness going to the screen by squeezing the tab on the connector - very easy to do.
4) Remove all the screws on the black plastic shroud - about 8 of them. Have someone hold your screen and gently lift the screen off. The black shroud I think still has some screws holding it in place that become visible once you lift the screen off.
5) Once the screen is off, there should be a set of screws that are holding the shroud down. Remove those and gently put the shroud on the floor where the mirror cannot get damaged.
6) Installation is reverse of the above.
Note: This would be a good time to clean the mirror and tops of the CRT bulbs. It will make your picture much nicer if it hasn't been done. Use a non streaking glass cleaner on the mirror and bulbs. For the screen, just wipe it down, don't spray it with glass cleaner.
2/26/2011 3:41:31 PM • Toshiba 42H83... • Answered on Feb 26, 2011
When i turned the t.v
The convergence chip that was supposed to control the blue CRT has failed so the convergence board must be refurbished. Here is the repair kit
http://www.tvrepairkits.com/xcart/product.php?productid=21827&cat=2726&page=1
2/11/2011 8:54:55 AM • Toshiba 42H83... • Answered on Feb 11, 2011
During football games the crowd noise drowns out
Go into the Audio menu and turn off surround mode. Put it in stereo and it should be fine. If you still have a problem, post a comment and I will help you further
1/16/2011 2:54:52 AM • Toshiba 42H83... • Answered on Jan 16, 2011
Toshiba 42h83.... The blue convergence will not
bmarino18,
Initially I would have told you to replace the convergence ICs but after reading your post carefully I think you could have a problem with the convergence box. The lines can only be bent/curved for two reasons. One - the yokes are bad causing an undue strain on the power supply and not being able to correct the problem. Two - the convergence box/board is bad and is not holding the settings causing the curve you see. I cannot tell you which problem you have. You wil have to determine this. I do have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which may be helpful.
Thanks for using FixYa and for the great rating.
hardrocko
12/8/2010 1:30:28 AM • Toshiba 42H83... • Answered on Dec 08, 2010
Light yellow line through center of screen from
You do not have a lamp in that model. You ave 3 individual picture tubes like an older glass tv style except tubes are a whole lot smaller. The yellow line you see is most likely caused by a foreign substance hanging from the mirror or laying on the face of one of the picture tubes. If your mechanically inclined and would like to take the back off you will see what I mean and be able able to clean your mirror with windex and the face of the tubes. See if that's the issue and let me know.
11/27/2010 6:28:04 PM • Toshiba 42H83... • Answered on Nov 27, 2010
How much is the tv worth used
If this TV is working fine...The first 250 to 300 bucks should be a reasonable high end price. Unfortunately if this TV has any kind of problem it may be worth much less.....50 bucks. And if it does not work...nothing! Everybody wants a new flat screen and will pay new prices to get one. The older projection and tube TVs are almost worthless now! Thanks for asking and show a few hands of support!
11/11/2010 5:24:32 AM • Toshiba 42H83... • Answered on Nov 11, 2010
2answers
The blue won't align with
HI:
One of your convergence IC have failed. I recommend having both of them replaced as the other may not be far behind to fail also, They are large OP-AMP IC's that control the beam in each of your picture tubes. They may use the part# STK-392-110, google this number for better info on the IC's and where to get them. If you know how to solder and unsolder electronic componets then you can install them yourself, saving you some money. They are the two or three LARGE BLACK IC's mounted on a large metel sink. Typical price for most local shop to repair this problem is $130-$210.00 depending on what IC's part number is installed.
11/10/2010 7:34:31 PM • Toshiba 42H83... • Answered on Nov 10, 2010
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
Popular Tags
152 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 42h83 tv sound but no picture
  • Televison & Video
