20 Most Recent
Nokia Lumia 520 Smartphone - Wireless LAN - 3G - Bar - Black AT&T SIM - Windows Phone 8 - Qualcomm Snapdragon S4 Dual-core 2 Core 1 GHz - 8 GB - 4" - LCD 800 x 480 - Touchscreen - Multi-touch Screen - 5 Megapixel - CameraQuad Band GPS Reciever - Bluetooth Questions & Answers
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
- Slide your finger left on the display.
- Press Settings.
- Press Bluetooth.
2. Turn on Bluetooth
- Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
- Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
- Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
- Press the required Bluetooth device (the tab should say Sync).
- Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
- The new device is displayed on the list of paired devices.
- Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
- Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com
Ford Tech Lane Driving you on the fastlane of vehicle technology
Unlock nokia 520
I suggest you can approach
Mobileunlocksolutions.com and specify the country,locked network of your Nokia Lumia 520.Based on the availability you can get the unlcok code along with free instructions.
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
