20 Most Recent Toshiba 36A50 36" TV Questions & Answers
Here's the list from Time Warner
http://www.timewarnercable.com/Carolinas/site.faqs/Equipmenta/Remotes/Digital-Remote-TV-Codes
Toshiba 36A50... | Answered on Jul 14, 2019
It is the fault with some components related with its horizontal scan output section circuit. Just check the circuit part; and check the components I've marked in red here by its horizontal scan output circuit. Beware; you're going to touch the most dangerous part of its circuit. Keep it in mind always.
24780559-dmive0z32bcpzrsafcaw1enm-4-0.jpg If you wish to see the circuit diagram in full; visit
http://schematicscom.blogspot.com/
Toshiba 36A50... | Answered on Aug 18, 2016
038,017,082,053,091 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Toshiba 36A50... | Answered on Apr 08, 2013
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
Toshiba 36A50... | Answered on Aug 04, 2012
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Toshiba 36A50... | Answered on Jul 22, 2012
hi,
Hi check is there is any dry soldering in the vertical scanning stage or in the power supply stage. of your tv. If the soldering of the vertical ic is dry( improper spldering contact coused by years of use) then this can happen.Thats why it disappears some time when there is a proper contact comes. You can confirm is it dry soldering by shaking the tv while its working. If the line comes and go off then there is dry soldering in the vertical scanning section. To rectify this you have to oppen your tv And have to resolder the points in the vertical section. Have added the picture, how a dry soldering point looks.
ok
Toshiba 36A50... | Answered on Aug 22, 2011
Toshiba 36A50 36" TV Logo
104 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 36a50 picture thin white line
  • Televison & Video
