20 Most Recent Archos AV 700 160-Hours Video Recorder Questions & Answers
Dc power input for av700
This isn't really a good answer but there was an external charger available at one time that was fairly inexpensive. The one I got came from China. http://www.newmp3technology.com/multibox2-700.htm
11/25/2013 8:18:10 PM • Archos AV 700... • Answered on Nov 25, 2013
0answers
Part of the screen of my macbook has gone dull
It seems as though you may have the wrong profile loaded for your Mac Book Pro screen which will affect the color temperature.Open the Displays pane of System Preferences and select the Color tab.Select the desired color profile.
Or you can also create a custom profile by clicking the Calibrate button in the Color tab of the Displays preference pane. This will open the Display Calibrator Assistant. Using expert mode, you can choose the color temperature you prefer.
If the Problem persists, then more often it is a Hardware Fault. You need to take the Mac Book to Apple Showroom to get it fixed.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
3/17/2010 8:56:19 AM • Archos AV 700... • Answered on Mar 17, 2010
Backlight is not working
my aplications all gone, how i can download them back?
12/13/2009 5:00:23 AM • Archos AV 700... • Answered on Dec 13, 2009
Hi there, i have an
Hello: When the charger blew it may of blown a surface mount protection fuse in the unit itself. I suggest you send the unit in for repair. Servicing this unit yourself will be difficult to do as you will need the exact type fuse to replace on the main board of this unit. The cost to repair should not exceed the cost of the unit itself.
11/22/2009 3:54:41 AM • Archos AV 700... • Answered on Nov 22, 2009
My Unit Will Not Power Up
Not sure if this is a solution for you. I had a problem with the DC power input jack on the player going bad. The batteries would no longer charge. I bought an extra battery and a USB charger from ebay. Now I'm good for two battery cycles and it works again. Although it will never charge it's own batteries or work off of AC power it does still work.
4/1/2009 7:08:58 PM • Archos AV 700... • Answered on Apr 01, 2009
Problem with the hard drive
your harddrive is corrupt..you have to reformat it
3/2/2009 8:09:07 PM • Archos AV 700... • Answered on Mar 02, 2009
My screen has gone dull
Not sure if I understand your question. If the screen is a bunch of colors with some jagged lines it may have been cracked. I had mine for less than a week and dropped a clock on it. Not a happy camper. It can still be used for transport of video. I have an old sony monitor in my garage office. I load the AV700 from my computer and plug it into the monitor to watch videos in the garage.
10/28/2008 1:24:00 AM • Archos AV 700... • Answered on Oct 28, 2008
Connection to tv
Hi karen your manual would help if have one.dont have a manual, then contact the following website www.partstore.com www.repairworld.com or samsphotofact.com,check them out and good give me an hooler at [email protected] if you are lucky.
8/2/2008 4:50:28 PM • Archos AV 700... • Answered on Aug 02, 2008
4answers
Damaged directory after pulling USB cable out from Mac?
If the Usb is not damaged first Try to connect to another mac system and check if it recognises the device...If not the Usb of the device is damaged!!..For your additional information!!..
The USB Port of the AV700 can be configured as "Hard Disc" or "Windows Device". Your Mac will recognize the device only if it is on Hard Drive mode.You can change the USB Port configuration of the device, in the menu Display Setup Screen > System> USB Port.
Please post back how things turned on or for further assistance..Thank you!!...
Regards!!...
7/31/2008 1:15:37 PM • Archos AV 700... • Answered on Jul 31, 2008
Sound problem
Make sure that the sound cables are connected,If you are using the RED BLUE GREEN cables,they do not carry sound.You have to run a set of sound cables RED AND WHITE to the Archos from the cable BOX or whichever component you are recording from.Good Luck.
5/10/2008 4:33:02 PM • Archos AV 700... • Answered on May 10, 2008
Display shows very very faint image. Can't turn device off.
Sounds as though your back light for the LCD may have gone. It is not a job the DIY repairer can easily complete therefor you should return it to Archos or a certified repair center for an estimate. If it is in warranty Archos MAY cover it, though if they deem it has been dropped will likely charge you.
7/26/2007 3:34:15 PM • Archos AV 700... • Answered on Jul 26, 2007
0answers
Have pocketdish AV700e with record but not play back videos
just a though I believe this follow is talking about his AV700E pocketdish trouble. I am here now with the same issue he is talking about AV700E pocketdish loads program video from the receiver onto the pocketdish, but when play on the pocketdish is selected it goes black screen and shuts down. Any advise?
8/16/2013 1:32:59 AM • Archos Televison... • Answered on Aug 16, 2013
What type of ac adapter do I need for the av700
I would suggest to check the plug on the av700 and see the polarity, it might be indicated there.
In regards to using any adapter, you could as long is the same polarity. The original adapter is 6 Volts and 2 Amperes.
5/21/2008 4:29:28 PM • Archos Televison... • Answered on May 21, 2008
Harwa Smart television. How to restore Apps, it doesn't want to open for Apps.
Check the internet connection. The television can't update if it can't see the internet. Resetting it breaks the previous settings. Just for fun, reboot the router as well and wait 15 minutes until all the lights come back on. Then reestablish the television connection to the router. Harwa is not a make we know here in North America. https://www.google.com/search?q=Harwa+Smart+television.+How+to+restore+Apps ..
4/25/2024 3:46:43 PM • Televison &... • Answered 15 hours ago
Archos AV 700 160-Hours Video Recorder Logo
18 questions posted
Top Archos Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Archos Televison & Video
Most Popular Question
unit will not power up
  • Televison & Video
