20 Most Recent
Yamaha WaveForce 192XG Sound Card Questions & Answers
Microphone hissing sound
That sounds alot like the microphone booster in control panel. Depending on what version of windows your are using, you can just open the sound control from the taskbar and go to the advanced settings and uncheck the setting "microphone booster". Adjust microhpone volume accordingly.
My CD NO HDMI WILL NOT PLAY THRU MY RX-V372 Yamaha RECIEVER with HDMI . So I tried to use rca plugs & no help must have made mistake. Can u help
Based on the information provided, it seems that the CD player is not compatible with the HDMI input on the Yamaha RX-V372 receiver. This is likely due to the fact that the CD player does not have an HDMI output.
In order to play the CD player through the receiver, you will need to use analog RCA cables. Make sure that you have connected the RCA cables to the correct inputs on both the CD player and the receiver. The CD player should be connected to one of the analog audio inputs on the receiver, such as "CD" or "Aux". Once you have connected the cables, select the appropriate input on the receiver using the input selector knob or button.
It is also possible that there may be an issue with either the CD player or the receiver. If you continue to experience problems, try testing each component separately to determine where the issue lies.
In summary, if your CD player does not have an HDMI output, you will need to use analog RCA cables to connect it to your Yamaha RX-V372 receiver. Make sure that you have connected the cables correctly and selected the appropriate input on the receiver.
I cant find a keyster carb kit for a 1981 yamaha xt 25j
1. Contact your local Yamaha dealer or motorcycle shops: They might have access to parts that are not available online, or they could have suggestions on where to find the specific carburetor kit you're looking for.
2. Join online forums or social media groups for Yamaha XT owners or vintage motorcycle enthusiasts: You might find other owners who have encountered similar issues and could provide information on where they found parts or recommend trustworthy suppliers.
3. Widen your search to include alternative brands: While you may be specifically looking for a Keyster carb kit, there might be other brands compatible with your Yamaha XT 25J that are more readily available in your region.
4. Reach out to international suppliers with good reviews: Look for reputable online sellers, like websites or eBay stores with positive customer reviews and good return/exchange policies, even if they are located overseas. Contact them to inquire about shipping to South Africa and any additional costs associated with it.
Yamaha rx-459 turns on & then turns off within 1 second.
The issue you're describing with your Yamaha RX-459 turning on and then off within 1 second is likely a thermal protection problem. The TMP PRT:000 H error code suggests that the unit is shutting down due to overheating. This can be caused by several issues such as a clogged air filter, inadequate ventilation, or a malfunctioning cooling fan. You can try cleaning the air filter and making sure the unit has proper ventilation. If the problem persists, it could be a sign of a malfunctioning cooling fan or another issue with the unit's internal components. I would recommend contacting a professiona
