20 Most Recent Gestetner RT45 1500 Sheet LCT 411339 Questions & Answers
Comment enlever l erreur sc194 bourrage papier porte de droite
faudrait bien regarder le sensor, il y a surement un bout de papier la
12/6/2016 7:19:39 PM • Gestetner RT45... • Answered on Dec 06, 2016
2answers
Ihave Gestetner 5327 an having
Check out the website www.arico1.com. They do repair on duplicator machine drums.
10/10/2021 2:53:28 PM • Gestetner Office... • Answered on Oct 10, 2021
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
1/15/2021 4:04:21 AM • Gestetner Office... • Answered on Jan 15, 2021
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website. This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this; Open the right side cover, unlatch all the bits at that side. Open the straight pass door on the left side. remove ALL the paper drawers. Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message. If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
1/14/2021 4:54:33 PM • Gestetner Office... • Answered on Jan 14, 2021
Gestetner DX2430 error code E-00
Clamper error The MPU cannot detect the clamper position sensor signal ( open or closed) within 3.0 seconds after the clamper
12/2/2019 1:38:38 PM • Gestetner Office... • Answered on Dec 02, 2019
Error code E-01 for gestetner dx 2430
i m gatting a E-00 error code geststner dx2430
6/4/2019 7:30:53 AM • Gestetner Office... • Answered on Jun 04, 2019
Sc 569 for ricoh mp 5500
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures: 1. Check or replace the harness of the pressure roller contact sensor. 2. Replace the pressure roller contact sensor. 3. Replace the pressure roller contact motor
6/2/2019 2:54:43 AM • Gestetner Office... • Answered on Jun 02, 2019
SC 569 Error code in MP 5500
6/2/2019 2:49:55 AM • Gestetner Office... • Answered on Jun 02, 2019
How to reset gestetner sp 8100dn aficio error sc547 power off on ?
Sc 547 is Zero cross error Troubleshooting : 1. Check the power supply source. 2. Replace the +24V fuse on the PSU. 3. Replace the PSU ( power supply unit)
6/2/2019 2:20:51 AM • Gestetner Office... • Answered on Jun 02, 2019
6/2/2019 2:19:34 AM • Gestetner Office... • Answered on Jun 02, 2019
How do i remove password from a gestetner Aficio 2212?
password word can be reset in special SP mode as follows: Reset, 1,4,3 press C then hold C special SP mode, go to SP direct 5-846-046 This will rest the Admin password to default
6/2/2019 2:12:38 AM • Gestetner Office... • Answered on Jun 02, 2019
What remove password on a gestetner Aficio 2212 copier
6/2/2019 2:11:54 AM • Gestetner Office... • Answered on Jun 02, 2019
Ink idling problem in gestetner dx 2330 copy printer
Hi Hope this helps.The metal gauze filter (see image) behind the input nipple on the drum unit may become blocked with congealed ink deposits causing the ink not to feed at full flow.Strip and clean the blocked gauze filter in the Ink Supply System.
4/29/2019 3:43:20 AM • Gestetner Office... • Answered on Apr 29, 2019
What do you do when the color registration adjustment fails on a Gestetner C2500
The ID sensors are dirty or transfer belt unit is damaged/dirty/faulty. The ID sensors are below the fusing unit facing down onto the belt. Usually best to remove the fuser unit and the belt unit to get to them with a short brush or unscrew to remove them but be very careful not to damage the transfer belt!
4/15/2019 10:02:41 PM • Gestetner Office... • Answered on Apr 15, 2019
2answers
Close the lower door while it was closed gestetner 1802 copier
Door switch not working
4/15/2019 9:55:53 PM • Gestetner Office... • Answered on Apr 15, 2019
How can I solve E14 code on gestetner copy priter 5308
Clean paper exit feeders
4/15/2019 10:33:57 AM • Gestetner Office... • Answered on Apr 15, 2019
Error code E-01 for gestetner dx 2430 - copy printer
Description. Cutter error The cutter HP sensor does not turn on within 3.0 seconds after the cutter motor turns on .
4/15/2019 10:32:48 AM • Gestetner Office... • Answered on Apr 15, 2019
How to fix e-12 problem
Your master cutter is jammed clean the Master cutter
4/14/2019 9:00:11 AM • Gestetner Office... • Answered on Apr 14, 2019
Gestetner DX 4542 not supplying ink
Ink pump motor may be not working first you need check your cp is original.. After that remove drum unit disabled the unit and clean ink detection sensor and ink pump motor
4/14/2019 8:58:08 AM • Gestetner Office... • Answered on Apr 14, 2019
Gestetner RT45 1500 Sheet LCT 411339 Logo
1 questions posted
Top Gestetner Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
comment enlever l erreur sc194 bourrage
  • Office Equipment & Supplies
