20 Most Recent
JVC AV-20220 TV Questions & Answers
Jvc channel lock
The default lock code is "0000" Then you can go in and turn off the V-chip.
Turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
My crt tv no pics but good sound
In a crt television, you have a special power supply for the huge voltage for the tube. That can be defect, but also the heater in the back of the tube can be defect. Actually more defects can make the tube is not working, while the receiver and the audio part still work fine. Could be a little thing, like a bad soldering place on the mail board, but be aware it is dangerous to open a CRT, because of the very high voltages. (Up to 30.000 volt on the tube) and the voltage can be there on the tube and in capacitors.
Don't spend to much money for the TV, because the new flat panel TV's are not that expensive anymore.
STOP TV FROM TURNING OFF AND ON
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience.
Pull up older posts.
Tv shuts itself off randomly (sleep mode problem)
This is wierd the kids played with your remote and you cannot get it out of sleep mode. Well here is somthing to try. You would take back cover off but here is the disclaimer (HIGH VOLTAGE INSIDE CAN CAUSE INJURY INCLUDEING DEATH) iF YOU NOT QUALIFIED OTAKE IT TO A TECH IF ITS SOMETHING MNOR IT WILL BE DONE WHILE YOU WAIT AND WILL NOT CHARGE YOU OUT THE YANG FOR A FEE. But if you inclined chekc the power supply unit and see if it is giving the correct current to the TV if not replace it. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Zenith menu without remote
Without a remote control, you can't program it.
If you wish to
buy its original remote control, you have to contact the authorized service
center. If you wish to buy a universal
remote control, you should know about, which brand remote control have setup
code to your TV/device brand. You should first make sure about the number of
digits in the codes to your device have.
There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this
detail by the code list attached to every universal remote control. The brand name of the remote control you
select isn't a matter; but, its code list should have setup codes to your
TV/device brand, otherwise you can't set it up with your device. For more
information; check the links given below, and find which brand remote
control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand
remote controls are given. Check it,
and determine which brand remote control should be bought, and buy that brand
remote control, according to availability. For more information, check these links.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sub-title always on
going to need that original remote, in closed captions area turn to off or one of the four CC that does not work in your area, on rare occasions the cable box if used can cause it also.
JVC AV-27820 turn on the a white line accross
HelloTotal failure of vertical sweep occured whic your JVC TV. There are mainly two resons for this fault.Loose soldering terminals of the vertical output IC is the first one. The second one is of failure of the vertical output IC itself. You have to locate this vertical IC. It can be located at the main board. Vertical IC will be screwed on to a metal heatsink to radiate heat from it while it works. You can identify it very easly, if you have knoledge in electronic circuts abd printed circuit boards. Resolder all the solder terminals of this IC first, by applying a little more solder; without making any solder bridge short in between the close adjecent solder terminals, and see whether it helps you. If not replace it with same type and number. OK.
