20 Most Recent
Mpio HD-300 MP3 Player Questions & Answers
WONT PLAY KNOW MUSIC
try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website
BRAND NEW MPIO HD300 Completely DOA!
It's a reasonably straightforward task. There are 2 screws at either side (near the top) of the player. You'll need a small Alan-key to remove these. Once this is done, carefully prise off the back cover and you'll be able to see the battery - at the back. Just un-clip the battery cable. - You might want to check the connection in the first instance, if however, the battery needs replacing see replacment battery model number below: -
UP325385A4H-UP325385A5H
Hope this heps
Nam1
MPIO HD 300 Freezes/Computer won't recognize
1. there is a reset button if the player is stuck, there is a hole on the front panel use a paper clip.
2. Hard Drive probably got disconnected from the FPC cable, you might need to open the player to fix this issue
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Hmm...well wnhen ever i charge
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
