20 Most Recent
Fender Starcaster Strat Electric Guitar - Color: GLOSS White - PERFECT FOR BEGINNERS! - stratacaster Body Type - Twin Pickups - Includes 8 watt AMP, gig bag, guitar cable, strap, stand, chromatic tuner, strings, pick & 8 Watt Tranz AMP Questions & Answers
Serial number N554137
You haven't asked a question. If you're looking for the year on a Fender Starcaster, you're missing a letter or two from the front of the serial number. I suspect you're looking for info about a different guitar than a Starcaster.
12/2/2015 3:49:23 AM •
Fender...
Answered
on Dec 02, 2015
Where is V193037
Guitar Info
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona
Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
3/22/2015 8:27:05 PM •
Fender...
Answered
on Mar 22, 2015
Have a fender strat serial V019217
It is a US strat! Congrats!
Guitar Info
Fender: Corona
3/22/2015 8:26:06 PM •
Fender...
Answered
on Mar 22, 2015
7671060
it is what you see in the add for a beginner it is made in china / Indonesia and is sold as a package deal and is not really worth anything after you buy it
8/26/2014 8:09:37 AM •
Fender...
Answered
on Aug 26, 2014
MN9332078
Your guitar was made at the
Ensenada Plant (Fender), Mexico
in the Year(s): 1999 - 2000
7/26/2014 12:17:24 PM •
Fender...
Answered
on Jul 26, 2014
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
12/15/2023 7:48:03 PM •
Fender Music
Answered
on Dec 15, 2023
How can i control 2 different fender hot rod deluxe 3's drive channels with just 1 footswitch? Thank you in advance
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience.
I recommend the Fender single button footswitch for this use - Type: Footswitch
Number of Footswitch Buttons: 1
Manufacturer Part Number: 0994052000
It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
11/22/2022 1:29:51 PM •
Fender Music
Answered
on Nov 22, 2022
Guitar amp input not working
Get inside it and check the connections to the plug especially any shielding / braiding. Resolder the connections.
4/17/2022 3:41:52 PM •
Fender Music
Answered
on Apr 17, 2022
