20 Most Recent
Activision Spider Man: Shattered Dimensions with Bonus Art Concept Book for Xbox 360 Questions & Answers
Hi i have just purchased
If you have other games that load perfectly fine then you unfortunately received a bad disc with bad sectors. In that case you can call Activision (with reciept) and let them know and they'll send you a new disc. If other games are giving you the same problem then your DVD Drive has gone bad (happened to me twice). You can send it into Microsoft for $99 to repair it or if you like to take things apart, you can buy a new drive (make sure the model number is correct) and install it yourself.
I installed Spiderman : Shattered
hi there,hm try a reinstall maybe,have you downloaded all the latest Video Card Drivers for your card?
If not,Do so and good luck.. regards,finphillips..
Please rate :)
I am having a problem.
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
