? 1:01
https://www.youtube.com/watch?v=4aTYi1exVlw
Jul 29, 2013 - Uploaded by carlos67538
Turned on Silent Mode and forgot how to turn off! I appreciateyou took ... BTW you come up first in a google for \Uniden Dect 6.0 silent mode/ !.
Page 61 from the Base Unit, there is Delete All. From the handset you have to delete 1 at a time.
With.the.phone.in.standby, .press.[ ].to.
delete.all.messages..When.the.answering machine asks you to confirm, press [ ].delete again..All messages are.
permanently.deleted.
https://www.manualslib.com/manual/184807/Uniden-Tru9480-Series.html?page=61#manual
https://www.uniden.info > download > ompdf
PDF
Uniden 2.4GHz cordless phones are designed and engineered to exacting standards ... NOTE: Illustrations in this manual are used for explanation purposes.
Unfortunately, handsets are not universal for Uniden cordless phone systems. The accessory handset for the EZX290 is compatible with the DECT1500, 2000, 2100, 300 and 2900 DECT 6.0 phone systems. The accessory handset for the D1660 is here: https://www.amazon.com/Uniden-D1660-DECT6-0-Cordless-Handset/dp/B004NEUIY2 .
I wish that I had better news for you. Unfortunately, the two systems (EZX290 and D1660) don't use same handshake codes.
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay.
I hope this helps.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
Disconnect the power cord from the base of both phones.
Take the battery out of each handset.
Wait for a few minutes.
Reconnect the power cord to the base of the newer version phone and insert its battery.
Wait for the phone to register on the base, which should take a few seconds.
Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
The older version phone should now register on the same base.
Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
Talk to your telephone service provider. There will be a fee.
(Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
