20 Most Recent
Durabrand 8.5'' Portable DVD Player Questions & Answers
How can i fix my portable dvd player?
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
Shows no disc when there is a disc loaded. Goes
- Hi, I can help.
- Sounds like the lens is dirty to me. When the lens is dirty it be comes difficult if not impossible for the disk to be read.
- Go buy a lens cleaner from Best Buy (or where ever) and put it into your player. These lens cleaners have bristles on them that "sweep" the lens clean.
- If real dirty you may have to run it through two or three times to get it to read completely right again.
- Sometimes if real dirty you may have to fool with it a bit just to get the lens to read the cleaning disk.
- Make sure the disk is the proper format and not scratched too. Disks can be resurfaced at your local video store for just a couple of bucks.
- Make sure the disk is from your region.
- If you do all of this to no avail then it is possible that your lens has come out of alignment and needs to be put back into position. A lens even 1mm out of alignment can mess up the ability of it to read properly.
- If you have any comments please feel free to leave them here.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
Who makes Durabrand portable DVD players? I can't
Durabrand is made by Funai along with:
Funai, Symphonic,
Sylvania, Emerson, Aventura, ESA, Magnavox, Insignia, Philips and Misakai
Unfortunately, all of these brands are to be avoided if you can afford to ignore the low prices.
Equally 'unfortunately' because of the potential recurrence of failures, many places won't accept them for repair and you are generally better off replacing the unit.
Don't like starting off your new year with bad news but . . .
When I install disk, ' No disk' shows on display.
IS the disc on a CD-R or CD-RW (burnt disc) some portable players will not support those types of disc's.
It could also be a different region dvd that doesnt match the region codes of the dvd player. There are no known region hacks for your make and model of dvd player.
Sorry and thank you for choosing Fixya! Post back with more info for further help.
Durabrand portable dvd player
Try a standard multi voltage charger.
These come with a selection of connectors each one of a specific size and color coded.
so you pick the connector to fit the input jack then set the charger to the appropriate color to give the correct voltage.
Smart tv durabrand modelo LE4206500DA , necesito actualizar el software , como puedo hacer ? gracias por su pronta respuesta
Hi Melvin, if you can download the firmware to a USB memory, empty it and install it on the TV
You have to find the firmware update, according to the model of your TV
I hope I can solve the problem
Greetings Franco Dosil
Hola Melvin, si puedes descargar el Firmware en una memoria USB, vac?a, e instalarlo en el televisor
Tienes que encontrar la actualizaci?n del Firmware, acorde del modelo de tu televisor
Espero pueda resolver el problema
Saludos Franco Dosil
6/15/2019 2:32:48 AM •
Durabrand...
Answered
on Jun 15, 2019
