20 Most Recent Konica Minolta Konica Bizhub C353 Drum Cyan Imaging Unit Questions & Answers
2answers
I have a trouble code C-3727 showing on my
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
11/6/2019 5:47:13 AM • Konica Minolta... • Answered on Nov 06, 2019
My yellow imaging unit is on back order, is there anyway to still use the printer until it gets here
Basically -no. If you could get a reset chip for it, you could probably carry on using the original drum for some time. For example http://www.tonerstop.com.au/konica-minolta-bizhub-c353-bundled-set-of-4-compatible-drum-chips
10/26/2016 4:28:37 AM • Konica Minolta... • Answered on Oct 26, 2016
My konica minolta c353 the screen is not displaying
See if you can get a new control panel. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/1/2016 9:54:02 PM • Konica Minolta... • Answered on May 01, 2016
When I make color copies the output copies are black&awhile pls help
I suggest checking the printer setup on your computer to determine if the default is black/white. On my Windows 10 computer, the color printer default can be changed between color and b/w.
3/18/2016 7:09:37 AM • Konica Minolta... • Answered on Mar 18, 2016
How do I correct error c4152?
Magenta Print head (print head has the LASER inside of it that writes the image on the drum) in this case it is the magenta LASER. Open and close the front door to reset. If it comes back replace the print head. Normal done as a set of all four. (Black, Magenta, Yellow, and Cyan). Worse case is the relay board is bad or the Image control Board$$$$$$$$$$$$$$$$. Try this site as a start: Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/6/2015 5:22:34 AM • Konica Minolta... • Answered on Jun 06, 2015
THE PRINTING IS TOO DARK
You may be able to "manually" change your colour balances settings through the printer settings on your computer. If the machine is stand alone or connected to a network, try getting the machine to recalibrate itself. If none of these have any significant effect - it will need to be seen by a service tech.
5/14/2015 9:13:19 PM • Konica Minolta... • Answered on May 14, 2015
2answers
On C35 bizhun get error when scan to email SCAN TX
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
1/30/2015 6:07:30 PM • Konica Minolta... • Answered on Jan 30, 2015
ERROR CO C-FC22
Sir/Mam, There is something wrong with Multi-function board. MFPB. Mite want to check all of the connectors on the board pull each one off check the pins then reseat them each !!!!!!! about 20 also check the board to board connections. The board cost about 1000 dollars give or take. Also mite be able to have at technician come out and re-flash the firmware, which can only be download from a secure Konica Minolta web site not on line for free. Also ensure your machine has a real good surge protectors not a $19.99 Ace hardware store one (Nothing against ACE:)) Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/2/2015 5:08:21 AM • Konica Minolta... • Answered on Jan 02, 2015
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/27/2014 5:05:18 AM • Konica Minolta... • Answered on Dec 27, 2014
Konica c353 double side print
ARE you sure you have checked the box on print properties on you computer that says either left binding or top binding have to let the copier know which way to do binding will go so you don't have to flip the paper over to read correctly or it will be upside down on the other side. Left binding like reading a book,top binding like a classroom lecture notebook. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/27/2014 5:00:55 AM • Konica Minolta... • Answered on Dec 27, 2014
I have Konica Minolta bizhub C353 and the paper
First Are informing the copier of the proper paper weight ? The paper weight is on the outer wrapping of the paper such as 75 g/m2 or 90 g/m2 etc. did you tell the machine that? Did you select the same weight when you sent the print job over to the machine in your print properties/perferencies ? They have to match! Check the orientation of the paper also ensue they match landscape or portrait? they have to match in the computer also. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
10/31/2014 10:46:41 PM • Konica Minolta... • Answered on Oct 31, 2014
When I print a page, the paper appears to have been twisted and the print is off the page on bottom left
There can be many reasons for this problem. All of them are connected with paper transport. What model is your printer? Try to find some small pieces of paper inside the printer. Something stops the paper to move correctly!
9/25/2014 8:38:49 PM • Konica Minolta... • Answered on Sep 25, 2014
C353 takes a long time to warm up and print
you can update the firmware, but it s not an easy way to do. It can help.
9/2/2014 11:07:41 AM • Konica Minolta... • Answered on Sep 02, 2014
I just replaced new transfer belt assymbly then error 2152 appeared
Sir, Open close front door. to reset. Ensure belt was install properly the code is for that device also check the transfer roller sponge one. ensure shipping parts remove before installation. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/17/2014 4:11:16 AM • Konica Minolta... • Answered on Jul 17, 2014
After replaced transfer belt unit its error 2152
7/17/2014 4:10:03 AM • Konica Minolta... • Answered on Jul 17, 2014
Error codes c2020
hI ARE U SURE ABOUT THE ERROR CODE OZ NOTHING ON SERVICEMANUAL ABOUT IT.
3/17/2014 11:42:16 AM • Konica Minolta... • Answered on Mar 17, 2014
ERROR CODE C2163
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
1/29/2014 9:42:35 PM • Konica Minolta... • Answered on Jan 29, 2014
I have problerm with konica minolta c353 .. the
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
12/13/2013 2:20:17 PM • Konica Minolta... • Answered on Dec 13, 2013
How to clean rollers
what rollers are you refering too?? you cant clean the image units. they need to be replaced
1/11/2012 6:07:32 PM • Konica Minolta... • Answered on Jan 11, 2012
Konica Minolta Konica Bizhub C353 Drum Cyan Imaging Unit Logo
20 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
yellow imaging unit back order anyway
  • Office Equipment & Supplies
