20 Most Recent Pentax ZX-50 35mm SLR Camera Questions & Answers
7/19/2016 10:12:49 AM • Pentax ZX-50... • Answered on Jul 19, 2016
0answers
Battery nikon
Be the first to answer 11/17/2013 4:01:23 AM • Pentax ZX-50... • Posted on Nov 17, 2013Be the first to answer
manual
Users manual zx50
You may download a copy of the manual here.
4/7/2013 4:20:38 PM • Pentax ZX-50... • Answered on Apr 07, 2013
Can't see through viewfinder
That will happen if the mirror is stuck in the up position and so blocking any light from entering the viewfinder.
Mirror lock-up is very common on 35mm SLR's like yours where the shutter is entirely electronically controlled and in most cases it's cured simply by fitting new batteries.
If this resolves your problem then please rate my answer, if not then add a comment instead to confirm that the batteries have been replaced and I'll try further options.
9/18/2012 4:16:25 AM • Pentax ZX-50... • Answered on Sep 18, 2012
Battery
It uses two CR2 or equivalent batteries. You can tell your sister she may download the manual here.
1/18/2012 9:52:28 PM • Pentax ZX-50... • Answered on Jan 18, 2012
Manual for pentax 8
You may please download the manual for the camera from this link.
If you require any further assistance, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
2/13/2011 6:50:30 AM • Pentax ZX-50... • Answered on Feb 13, 2011
Looking for a manual-
1/29/2011 3:05:01 AM • Pentax ZX-50... • Answered on Jan 29, 2011
The shutter on my Pentax zx-50 SLR is stuck in the
if its just a sticky mirror you could try to very genteely flip it down again but if the shutter is jamed in its sliders it could need to go to a camera shop to get it "fully serviced!" also check its not just the shutter lock button stuck in, or the shutter is locked open,
11/30/2010 10:23:50 PM • Pentax ZX-50... • Answered on Nov 30, 2010
The mirror inside the camera has flipped up and
The ZX-50 does not have a mirror lock up feature so there are several possibilities for the problem. There could be residue on the foam padding where the mirror hits the inside of the camera frame causing it to stick. In this case the foam may need replacing and the inside frame cleaned. Checking with a camera dealer in your area will answer the question in more detail.
10/28/2010 10:56:12 PM • Pentax ZX-50... • Answered on Oct 28, 2010
2answers
THE SHUTTER STUCK OPEN AND NOTHING HAPPENS, EXCEPT
loader gear broken,get it replaced ,get it done by a camera tec.
9/8/2010 12:57:54 PM • Pentax ZX-50... • Answered on Sep 08, 2010
I just bought a camera
SLR stands for "Single Lense Reflex", and yours is not reflexing, the shutter is stuck. I would say the guy that owned it before you did not know it, because to reset it manualy you have to remove the film and or the lense. To fix it you have to send the camera in for a good cleaning. "proffesonal job, lots of small tools and touchy parts"
9/6/2010 1:40:50 AM • Pentax ZX-50... • Answered on Sep 06, 2010
Film won't advance
check the sprockets on the roller..whether they are broken or not?If not there might be problem inside the roller that locks the sprockets to rotate in one direction only when the lever is pulled....you have to open that mechanism very carefully as there are tiny parts inside.
8/21/2010 11:11:15 PM • Pentax ZX-50... • Answered on Aug 21, 2010
Auto focus doesn't work
clean the cotacts of the lens and camera,use new good batteries.
4/9/2010 4:42:03 PM • Pentax ZX-50... • Answered on Apr 09, 2010
I cant find the manual for pantax ZX5 camera with
Try http://www.devicemanuals.com/guide/Cameras/Pentax-manuals-page2.html.
1/11/2010 11:26:29 AM • Pentax ZX-50... • Answered on Jan 11, 2010
What is the best film to use in the ZX-50
use ISO Kodak 400 as a start. Remember that the higher the speed the higher the grain. So if you want to enlarge to poster size a lower ISO speed will give the less grain, ( sharper image ).
12/27/2009 2:06:13 AM • Pentax ZX-50... • Answered on Dec 27, 2009
Fresh batteries and will not turn on??
Batteries inserted correctly? Check manual. I know that sounds stupid, but people do it. If the batteries were ever put in upside down, it may have shorted the electronics.
Also, batteries CAN go dead on the store shelf.
Battery contacts corroded?
If all that's OK, then we can assume a power switch problem unless this model has some unusual special handshake to get the power past the switch, LOL. Please check your manual. Yes, this probly means repair.
10/15/2009 11:10:00 PM • Pentax ZX-50... • Answered on Oct 15, 2009
Mirror sticks in the up posit, and advancing
My mirror contacts a kind of foam substance on the upswing. It got sticky a while back and I had the same problem as you. I dampened a cotton swab in rubbing alcohol (91%) and rolled it back and forth many times over the foam. Let it dry and my mirror doesn't stick any more. Might work for you.
8/12/2009 11:42:55 PM • Pentax ZX-50... • Answered on Aug 12, 2009
Pentax MZ50/ZX50 - no photo when shutter is pressed
first make sure the mirror is fully down. if down
take your MZ50 to a camera store and try a different lens. if it does the same thing then your camera needs repaired. flex circuit,
if the different lens works then the lens needs repaired.
7/22/2009 9:59:52 PM • Pentax ZX-50... • Answered on Jul 22, 2009
Pentax ZX-50 35mm SLR Camera Logo
33 questions posted
Top Pentax Photography Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pentax Photography Expert? Answer questions, earn points and help others
View Most Popular
Pentax Photography
  • Pentax Photography
Most Popular Question
users manual zx50
  • Photography
